Kunena move to crowdin for the translations
Like announced in the release nots of the K6.4 RC4 release, Kunena project has moved to crowdin : crowdin.com/project/kunena-forum to manage translations from K6.4 and beyond. The RC4 release is the last version before the stable, so for all translators please update your translations on crowdin.
Transifex is keept for translations from K6.3 and the previous versions of Kunena.
Kunena 6.3.10 Released
The Kunena team has announce the arrival of Kunena 6.3.10[K 6.3.10] in stable which is now available for download as a native Joomla extension for J! 4.4.x/5.0.x/5.1.x/5.2.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 and issues discovered during the last development stages of K 6.3
Note: Please go to the Kunena Dashboard after an upgrade so that the Kunena database tables are also updated.
Question [beendet] Fehler im Kunena wegen fehlender Tabelle
15 years 11 months ago #11 by Lintzy
-- Tabellenstruktur für Tabelle `jos_fb_version` -- CREATE TABLE IF NOT EXISTS `jos_fb_version` ( `id` int(11) NOT NULL auto_increment, `version` varchar(20) NOT NULL, `versiondate` date NOT NULL, `installdate` date NOT NULL, `build` varchar(20) NOT NULL, `versionname` varchar(40) default NULL, PRIMARY KEY (`id`) ) ENGINE=MyISAM DEFAULT CHARSET=utf8 AUTO_INCREMENT=2 ; -- -- Daten für Tabelle `jos_fb_version` -- INSERT INTO `jos_fb_version` (`id`, `version`, `versiondate`, `installdate`, `build`, `versionname`) VALUES (1, '1.0.8', '2009-02-17', '2009-03-02', '1166', 'Speakup!');
15 years 11 months ago #12 by neo67
graf wrote:
wie hast es unter 4.1 zum laufen bekommen ?
sowas möglich auch mit 4.3.0 ?
zuerst habe ich FB installiert, dann wieder deinstalliert. Dadurch habe ich aber die nötigen Tabellen und danach installiere ich kunena. Es gibt zwar dann eine Fehlermeldung, aber das Teil läuft ^^.
Dann das SQL Statement (steht hier im Beitrag) wegen der fehlenden Tabelle ausführen und gut ist. Mir fehlt jetzt nur noch der Inhalt dieser Tabelle.
Und das wird sicher mit 4.3 auch funktionieren.
Gruß
Jürgen
15 years 11 months ago #13 by neo67
Danke Lintzy,
jetzt läuft das Forum gut. Ich musste noch, nach Kopieren der deutschen Dateien auf Server, in der Administration die Bildersets auf "default" setzen. Aber jetzt läuft es. Danke für den Support
15 years 11 months ago #14 by MacJoomla
Time to create page: 0.374 seconds
