Kunena 6.2.6 released
Loved Yes, it really IS possible to install K 1.6.4 on Joomla 1.5!
12 years 11 months ago #11
by xillibit
Replied by xillibit on topic Re: Is it possible to install K 1.6.4 on Joomla 1.5?
I need to check it by myself
12 years 11 months ago #12
by xillibit
Can-you just export the table jos_fb_version and give me the result ?
12 years 11 months ago #13
by blindek
Replied by blindek on topic Re: Is it possible to install K 1.6.4 on Joomla 1.5?
These is the resoult:
-- phpMyAdmin SQL Dump
-- version 3.3.2
-- http://www.phpmyadmin.net
-- Host: localhost
-- Generation Time: May 16, 2011 at 10:13 AM
-- Server version: 5.0.51
-- PHP Version: 5.2.6-1+lenny9
SET SQL_MODE="NO_AUTO_VALUE_ON_ZERO";
/*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
/*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
/*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
/*!40101 SET NAMES utf8 */;
-- Database: `codsi2_joomla2`
-- Table structure for table `jos_fb_version`
CREATE TABLE IF NOT EXISTS `jos_fb_version` (
`version` varchar(10) NOT NULL default '',
`date` int(8) NOT NULL default '0'
) ENGINE=MyISAM DEFAULT CHARSET=utf8;
-- Dumping data for table `jos_fb_version`
INSERT INTO `jos_fb_version` (`version`, `date`) VALUES
('1.0.5NB2', 2008);
12 years 11 months ago #14
by xillibit
Delete the table jos_fb_version and do this instead :
Then you can try if upgrade works to k1.6.4
`id` int(11) NOT NULL AUTO_INCREMENT,
`version` varchar(20) NOT NULL,
`versiondate` date NOT NULL,
`installdate` date NOT NULL,
`build` varchar(20) NOT NULL,
`versionname` varchar(40) DEFAULT NULL,
PRIMARY KEY (`id`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=2 ;
-- Contenu de la table `jos_fb_version`
INSERT INTO `jos_fb_version` (`id`, `version`, `versiondate`, `installdate`, `build`, `versionname`) VALUES
(1, '1.0.5RC2', '2008-10-06', '2011-05-15', '803', 'Redwood');
12 years 11 months ago #15
by blindek
Great, it woks!! Thank you very much. New 1.6 is realy really much better. GJ guys.
12 years 11 months ago #16
by Matias
Replied by Matias on topic Re: Is it possible to install K 1.6.4 on Joomla 1.5?
It looks like you had nightly build 2 from FireBoard 1.0.5 -- you should never upgrade any software from internal nightly builds into anything else than the closest stable release.
Nightly builds are only meant to be used to testing and often there's no upgrade path from them.
Time to create page: 0.346 seconds
