Question kunena doesn't exist in component menu!!
15 years 6 months ago #93819
by Yashine
kunena doesn't exist in component menu!! was created by Yashine
I just install Kunena successfully this morning and after the installation the kunena configuration show for me and every thing fine. but whene I backed now I couldn't find the kunena in the component menu in the Backend of joomla 1.6.
Help me please how can I fix this problem?
thanks.
thanks.
The topic has been locked.
15 years 6 months ago #93837
Replied by sozzled on topic Re: kunena doesn't exist in component menu!!
Maybe you uninstalled Kunena? Try re-installing Kunena again.Yashine wrote: I just install Kunena successfully this morning and after the installation the kunena configuration show for me and every thing fine. but whene I backed now I couldn't find the kunena in the component menu in the Backend of joomla 1.6.
The following user(s) said Thank You: Yashine
15 years 6 months ago #93844
by Yashine
Replied by Yashine on topic Re: kunena doesn't exist in component menu!!
No Kunena still exist in extensions page but note in component menu. well I will try re-install it as you said
thank you "Sozzeled".
15 years 6 months ago #93874
by xillibit
Replied by xillibit on topic Re: kunena doesn't exist in component menu!!
Which exact Joomla version do you have ?
15 years 6 months ago #93911
by Yashine
15 years 6 months ago #93921
Good to hear that you've fixed the problem of the "missing component". It sounds like you did not install Kunena according to the correct procedure. The correct procedure is described in
K 1.6 Installation Guide
That's the end of this topic. The problem with the way your Kunena menu displays is a completely different subject. Please search this forum for other cases that might help you, or create a new topic in the K 1.6 Template and Design category. Do not forget to include your K 1.6 configuration report next time.
