- Thank you received: 1
Question Change legend colours: Site Administrator, Global Moderator, etc.
sorry if my question is off-topic. thanks for any help.
I'd like to know this too.... ZYNC, i see, by your forum, that you figured out the answer to your question.... Would you mind sharing, please?ZYNC wrote: where in the backend of the joomla/kunena settings do i enable the colors-legend? i'm not sure why there's no color codes anymore in my forum index page at www.chat.com.ph/forum
- Jiminimonka
- Elite Member
- YBAS!
To change the legend colours, add the following lines at the end of your Joomla site template CSS file:
PS - didn't help
I've tried to insert a color code into that (ie color: #CD3F01 !important;) but nothing changed either...
- Jiminimonka
- Elite Member
- YBAS!
sozzled wrote: To change the legend colours, add the following lines at the end of your Joomla site template CSS file:
You mis-read Sozzled's post.
- Jiminimonka
- Elite Member
- YBAS!
As I said, you mis-read Sozzled's post, you should not edit the Kunena CSS file, you should be editing the Joomla CSS file.
I only have one question here for danss2: which file did you change? In this case you should add your changes to the end of the file ../templates/ja_social/css/template.css. The answer will be different in everyone else's case. It all depends on which file is the main Joomla site template CSS file. Only you know which file is your main Joomla site template CSS file.
There is a reason why, if you try to modify the file kunena.forum.css things won't work (see Minified CSS ) just as there are many good reasons why you should not modify any original Kunena source files. Please upgrade to K 1.7.2 and then add the changes that you need to the end of your Joomla site template CSS file.
