Kunena 6.4.9 & Kunena 7.0.1 Released
The Kunena team has announce the arrival of Kunena 6.4.9 [K 6.4.9] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
The Kunena team has announce the arrival of Kunena 7.0.1 [K 7.0.1] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question Weird layout in profile section
(and I'm very happy with the time and effort you are taking to help, be sure of that!! I would really like to pinpoint my problem so I can use K1.6!!!)
&template=rhuk_milkyway
I'm completely lost now...
So, change your site to something that works. The template that you've been using does not work.All of your problems (including the menu font sizes) are caused by your Joomla site template. There is a solution but it requires work on your Joomla site template. Your Joomla site template CSS has some very prescriptive font-size and line-height settings; these need to be changed. Firebug for Firefox is a way to analyse what's happening. These things can probably be quickly fixed with a different site template or, if you can't do them yourself, engage someone to do them for you.
**EDIT**
I'm sure it has something to do with a standard Artisteer function. I just made another template, and the only things I did were:
- Layout: only header, two columns
- background
- header pic
Thats all. The template is called loopgroep20 and I tested it the way you said (with &template=loopgroep20). It scr*ws the layout up even more. So I think we have to search somewhere for an option to make an complete new template....
Anyway, thanks for your help so far.
**EDIT 2**
I installed the Dutch translation as you suggested. After that, I looked at the site again, with &template=rhuk_milkyway. Here's the result..:
