Kunena 6.4.9 & Kunena 7.0.1 Released
The Kunena team has announce the arrival of Kunena 6.4.9 [K 6.4.9] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
The Kunena team has announce the arrival of Kunena 7.0.1 [K 7.0.1] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question Weird layout in profile section
15 years 4 months ago #60232 by gyedema
In one of the above posts I named the original website: www.loopgroepleeuwarden.nl
On that site 1.5 is installed. The 1.6RC2 version is installed for testing reasons on another site.
I would love to hear suggestions on how to make it work...!! I can alter the template in Artisteer but don't know where to look, other than just more pixels in the widht section of the pages..
15 years 4 months ago #60234 by sozzled
Let's remain focused on the K 1.6 site, please.
You will need to alter the site template. I would get rid as many font-size and line-height CSS styles that I could. I would look at ul, li, div, a, table, td, etc.
The following user(s) said Thank You: gyedema
15 years 4 months ago #60271 by gyedema
OK! Again, thanks alot for your cooperation and support. I will try to eliminate all those codes, and hope the website will remain -more or less- in the same layout.
I can post the results no earlier than somewhere next week; we're departing tomorrow morning for a short stay at Mallorca. Just to let you know why I'm not responding.
15 years 4 months ago - 15 years 4 months ago #61039 by gyedema
sozzled wrote: Let's remain focused on the K 1.6 site, please.
**Back again**.
You state in above post "lets focus on the K1.6 site". However, on the original website ( www.loopgroepleeuwarden.nl ) which uses the K1.5 site, there are no problems whatsoever with templates or layout. When I install 1.6, the layout starts to act weird.
To be sure, I changed the template to the Joomla Default "Beez" on the testwebsite with K1.6. And also in that standard joomla template, the layout of the forum is incorrect. The toprow is in correct layout, but when trying to change the avatar, columns are too wide, and the entire forum is displayed too low.
So I'm still not sure what part of the template I should change or edit...?
Last edit: 15 years 4 months ago by gyedema.
15 years 4 months ago #61311 by gyedema
Replied by gyedema on topic Joomla and Kunena 1.6
I'm rather desperate so I'll post again..
I have a website live ( www.loopgroepleeuwarden.nl ) with Joomla 1.5.18 and Kunena 1.5 forum. Everything is OK there.
When I install Kunena 1.6 (RC2), the layout is all messed up. Earlier answers were that all the errors were in the Joomla (Artisteer) template. However: if I change the template to the standard Joomla Beez, the errors still remain!!
So I'm stuck at the moment and don't know what to do. I would love to install K1.6, but can't because of the layout errors. I installed 1.6 as a test on www.lebowskirocks.nl/loopgroep (Joomla 1.5.20) and if you would like to check, you can login with user and password kunena. All help is highly appreciated!!
15 years 4 months ago - 15 years 4 months ago #61313 by sozzled
Please do not start other topics as a way of continuing something you asked earlier but to which you did not get the response you wanted.
Let us look again at the problem.
You have a problem with the website www.lebowskirocks.nl/loopgroep ... actually you have several problems with this website. You haven't got a working Dutch language translation pack for K 1.6; that's one problem for starters.
You have problems with the size of Kunena menu tabs. The microscopic size of the Kunena menu tabs is caused by your site template.
You have a problem with the layout of Kunena; the layout problem is caused by your site template.
sozzled wrote:
All of your problems (including the menu font sizes) are caused by your Joomla site template. There is a solution but it requires work on your Joomla site template. Your Joomla site template CSS has some very prescriptive font-size and line-height settings; these need to be changed. Firebug for Firefox is a way to analyse what's happening. These things can probably be quickly fixed with a different site template or, if you can't do them yourself, engage someone to do them for you. Perhaps someone else has a few more ideas?
There is an easy way to verify this: use the rhuk_milkyway template as a test. I don't know anything about the Beez template; we did not use the Beez template during the testing of K 1.6.
Last edit: 15 years 4 months ago by sozzled.
Time to create page: 0.640 seconds
