Question Changing colors of my Kunena forum
I'm afraid I don't have the skills to properly change the colors correctly. Is there any forumtopic known here where I can hire someone to do it for me?!
Grtz,
Goodboy.
- 9themestore
- Premium Member
I think, if you want to change the color of the kunena template, you must override the color property of the some element tag. And you should override it in the kunena.forum.css file.
9themestore wrote: Hi,
You open the kunena.default-min.css file in the default template and add the following code section:
Code:body #Kunena .kheader span, body #Kunena .kheader a { color: #ccc !important;}
and
Code:body #Kunena .kheader a:hover { color: #fff !important;}
I hope it work.
Ok I will try this one first. But all my css files in the template manager say in red color: unwritable now.. don't know whats wrong!
Edit: Oh.. and trying to reinstall Kunena give the next error:
Kopying failed
JInstaller: :Installation: Kopying file /home/deb47108/domains/wheelblog.nl/public_html/tmp/install_4de0c3f3676bb/kunena.php to /home/deb47108/domains/wheelblog.nl/public_html/components/com_kunena/kunena.php failed
- 9themestore
- Premium Member
I used the firebug and try to edit. it work. I can help you if you send me the ftp account.
I am using "blend with template" option checked. When I unchecked it, it changes the white text on the back background to black and the blue section titles to black.
Thank you
I did spend 3 full days trying to figure this out on my own before running to the forums, and I understand this is a free product - but any additional help you can give is much appreciated. I'm not even trying to do anything fancy here - just change some text color. Thank you
Obviously, though, the location and filename of your Joomla site template will be different.sozzled wrote: I'll give you the solution to the category link colour issue now:
Add the following lines to the end of your site template file (../templates/templatewheelblog/css/template.css)
Code:#Kunena div.kthead-title a { color: black; } #Kunena a:link, #Kunena a:visited, #Kunena a:active { color: black; } #Kunena a:hover, #Kunena div.kthead-title a:hover { color: red; }
