Question Why did 1.6.1 change my link colour (and how to fix it?)
templates/your_template_name/css/template.css
The name of the template will be based on what template you're using and the template.css file may or may not be named that, but find the main CSS file there.
Or you can also go into the Joomla admin backend and go to Extensions > Template Manager. Click on the name of your active template and click the Edit CSS button. Edit the main CSS file there by adding the CSS chunk to the bottom of it.
- bigmike0601
- Senior Member
- Thank you received: 2
severdia wrote: You can access it via FTP at:
For some reason my test site does not have an extension manager...I do not see an option to edit CSS in backend. My live site does have the extension manager, but I prefer to test on this site first. Below is the screen shot of backend...any reason why im missing the extension manager?
- bigmike0601
- Senior Member
Thanks for your help, but I have one more question. I want to keep the link color of the categories white, but change all the others. The code you gave me changed them all including the category links.
Thanks!
Mike
www.kunena.org/forum/170-k-16-templates-...y-kunena-16-template
There's a CSS block there with comments next to each part so you can pick and choose what you want to change.
- bigmike0601
- Senior Member
You see the links are all green except the forum headers are white.
You might find the article Which came first? The template or the forum? interesting reading in relation to your observations.pickykim wrote: Can you tell me where I would change the font of the main HI categories? It used to show up as my template font Segoe Script but now it is just some sort of default Tahoe or something. Jeesh, between modifying the joomola template, modifying the jomsocial template and modifying the kunena template, I'm going bonkers.
You can solve most of these template issues - these CSS issues - yourself if you use the web design tools that come with your browser (or download and install Firebug for Firefox ) and the article Firebug in the Wiki will show you how. You can then add your own CSS styles to your Joomls site template file.
No version of Kunena installs Alpha User Points. AUP is a separate Joomla extension that you have to download and install yourself. K 1.6 has configuration options that allow you to integrate AUP with your Kunena forum. I hope that answers your question.pickykim wrote: One other quick question. I know Kunena 1.6.3 came with alpha user points. however, once i upgraded to jomsocial 2.2, i cannot use them. Is this something I need to ask about here at kunena, at jomsocial (which would be a joke) or alphauserpoints people?
- woonydanny
- Elite Member
- Thank you received: 21
Troneas wrote:
sozzled wrote: OK, I'm not sure why the the user thinks this issue has something to do with K 1.6.1 support. I moved this topic to the Template & Design category for the simple reason that the issue concerns a template that is not a core component that was developed or that is supported by the Kunena project.
Thank you, Troneas, for solving this particular issue. I am sure that there are many people who appreciate your contributions.
Troneas wrote:I would say that this was actually a disingenuous attempt to needlessly blame the Kunena developers for something that is not within their ability to control. Please check, next time you blame someone, who is responsible for what you have chosen to use.i'd say that after the infamous new kunena menu, this was yet another clever way to complicate and confuse the user unnecessarily.
this would all be true if the initialize.php file was located in my chosen template (ie: aphotic).
but its not.
its located in the Default (blue eagle) template, which comes with kunena, updated in this last patch, and for some reason its affecting MY chosen template CSS. so in essence i had to change the settings of a file in another template (kunena's default) to change mine to what it was.
but anyway, sorry about the previous rant.
As the user above said, this is very annoying as this initialize.php file is not within your created template folder but yet still affects your template.
I dont understand what this initialize.php file is for?
I think it is getting the parameters that you set in the default Blue Eagle template for colours, however it really annoys me if i am not using the default template and have copied the example folder and made my own template it still is overriding my colours.
Please fix so that this doesnt happen when you create your own template!!
(Sozzled please first understand the issue before writing a page long essay)
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile
