- Thank you received: 2
Kunena 6.2.6 released
Question [Merged topic] K 1.6/1.7 - colouring categories
I've been tinking... I use a joomla template (changed to my own needs) derived from a Themza template.
(Colourfull world it was)
They use the following solution to choose a colour variaty in the template:
- In their templateDetails.xml:
<params>
<param name="colorVariation" type="list" default="blue" label="Color Variation" description="Color variation to use">
<option value="blue">Blue</option>
<option value="dblue">Dark Blue</option>
<option value="pink">Pink</option>
<option value="green">Green</option>
<option value="orange">Orange</option>
</param>
</params>
Next to this a file called 'params.ini' containing the following:
colorVariation=blue
and in their 'index.php' the following statement:
<link rel="stylesheet" href="<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/css/<?php echo $this->params->get('colorVariation'); ?>.css" type="text/css" />
With this one can choose a 'colourVariation' in the template settings (dropdown list)
Maybe this might be an idea to incorporate in Kunena's templates.
Those users, who are 'clever' enough, might be able to change things in the 'xml'-list as well as in the 'css', to meet theis specific needs.
Otherwise Kunena just offers an scale of colour variations as the, more or less' do now in a 'simpler' way.
It is just a though I had...
If my idea is too complicated, never mind my suggestion.
However, if it is something to build in, t was just a suggestion. I'm not wanting to 'own credits' for it.
Anyway, I'm going to 'play around' with your help.
- marshalrosy
- Visitor
For each category in the Category Manager, at the bottom of the Settings tab, there is a field called Forum CSS Class Suffix, with the description: "CSS suffixes applied to index, showcat, view, and allow for different designs per forum."
Can someone give me an example of how this works? In particular, I would like a given category to have a different appearance (text color or background) in the Index and Recent topics.
I believe it used here on this forum. If you go to the Index page, the section dedicated Kunena 1.5 has a darker background than the rest of the categories. I assume this is done using the Forum CSS Class Suffix.
Thanks.
I have searched the forum and could not find an answer. I have also check kunena config in backend and could not figure it out.
How do you get color coded categories?
How do I color an entire section?
I set it to No and I can colour categories now. Thanks.
- Jiminimonka
- Elite Member
- YBAS!
