Kunena 6.4.8 Released
Question Different "title" font colours for different categories using the CSS suffix
13 years 10 months ago #119508 by sozzled
Angela1 wrote: This is what I want to change: I want this page and all the other ones that are not the main page to have a different font color; orange in the main page and white in all the others
I think this should still be possible to achieve, using the CSS suffix.
You will need to add the following lines to the end of your Joomla site template CSS
#Kunena .krow2-green div.kthead-title a { color: white !important; } #Kunena .krow2-blue div.kthead-title a { color: white !important; } #Kunena .krow2-grey div.kthead-title a { color: white !important; } #Kunena .krow2-red div.kthead-title a { color: white !important; }
I think this will work for you.
Let us know how this works out for you. It would help, if you have more questions on this subject, to provide us with the location of your website. Thanks. :)
The following user(s) said Thank You: Angela1
13 years 10 months ago #119733 by Angela1
i've been trying.. but no! I give up.
Thanks anyway.
13 years 10 months ago #119735 by sozzled
Do you know which file is your Joomla site main template CSS file? I don't know the answer in your case because you have not told us where your site is ... and every site is different.
13 years 10 months ago #119736 by Angela1
yes i know, but .krow2-green... doesn't work for me
13 years 10 months ago #119738 by sozzled
I assume, because you did not answer my specific question, that you do not know the filename of your Joomla site main template CSS file. Am I correct in my assumption? Because I don't know the address of your website, I can't give you a specific answer that will solve your particular problem. If I knew how your site was set up - if you had posted your configuration report, for example - then I could have answered this question 4 days ago.
Time to create page: 0.312 seconds
