Kunena 6.4.8 Released
Question [Merged topic] Kunena Notice: Menu item /forum (Itemid=nnn) does not have Kunena Menu
15 years 1 month ago #81 by CoryPedersen
Replied by CoryPedersen on topic Problem with menu item
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.6.288) | UddeIm: Disabled or not installed
Hi all,
I downloaded and installed the latest version of Kuena on my site yesterday. I've created a menu item to the forum, however, whenever I access the forum, I get the following error message at the top of the page: * Kunena Notice: Menu item /forum (Itemid=158) does not have Kunena Menu.
Any idea what's going on or what I need to do to fix this? Thanks!
Cory
15 years 1 month ago #82 by ipsi
Replied by ipsi on topic Problem with menu item
same problem
15 years 1 month ago #83 by haithun
Replied by haithun on topic Problem with menu item
Please use the search function here before asking the same again and again.
www.kunena.com/forum/168-k-16-support/63...not-have-kunena-menu
@Moderator: I think that the merged topic should be fixed at forums top
15 years 1 month ago #84 by CoryPedersen
haithun wrote: Please use the search function here before asking the same again and again.
I did do a search before posting. Nothing showed up in my search results. Regardless, thanks for the information.
Cory
15 years 1 month ago - 15 years 1 month ago #85 by sozzled
G'day, CoryPedersen, and welcome to Kunena.
There are a few discussions running at the moment about problems that people are having with the Kunena menu. Searching for menu problems may give your some ideas but, as you will discover, it's a broad-ranging subject.
While I have your attention, I notice that you are still running J! 1.5 in legacy mode. In order to avoid emerging problems in the future, we strongly encourage people to disable the System - Legacy plugin. Please read important information contained in Legacy mode in the Wiki.
Last edit: 15 years 1 month ago by sozzled.
15 years 1 month ago - 15 years 1 month ago #86 by gray
Short notice:
I fixed the problem by chaining alias of first item (Forum) in KUNENA MENU (separate group of menus) to 'forummain' instead of 'forum' as it was.
I have another item in MAIN MENU group with has alias 'forum'.
That was causing troubles - I had 2 menu items with the same aliases.
PS. it seems that kunena menu is created by default with 'forum' alias. And 99% users would have 2nd menu item with alias 'forum'. Maybe it's better to assign different one when Kunena menu is created people not to write posts on the support forums.
www.justPHP.net - Custom coding for Joomla!
Last edit: 15 years 1 month ago by gray.
15 years 1 month ago #87 by sozzled
gray wrote: PS. it seems that kunena menu is created by default with 'forum' alias. And 99% users would have 2nd menu item with alias 'forum'. Maybe it's better to assign different one when Kunena menu is created people not to right posts on the support forums.
That's a good point and it's a question that that Kunena developers are wrestling with. One idea is that the Kunena installation procedure should not automatically create any menus at all and leave the job of creating menus to the user as a post-installation step.
I don't know if "99%" is a reasonable estimate of the number of people who find themselves in this situation. Based on the number of queries we receive in these forums the figure is more likely to be less than 10%. Most sites that I've seen where Kunena has been used (and I've probably seen over a thousand in the 18 months that I've been a member of this wesbite) only have the one menu item that links to their forum.
15 years 1 month ago #88 by schiarla
i've this problem when I enter in Kunena.
Is it possible to put Kunena Forum in the Applications menu?:)
15 years 1 month ago #89 by xillibit
look this doc : www.kunena.com/forum/168-k-16-support/63...-index-recent-topics
What do you mean by putting kunena froum in Applications menu ?
15 years 1 month ago - 15 years 1 month ago #90 by schiarla
working with jomsocial, i would insert in Application menu where there are My Applications, Browse application, Photos, Videos, Events, also the link with Kunena Forum... Thanks
Last edit: 15 years 1 month ago by schiarla.
Time to create page: 0.312 seconds
