Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question [Merged topic] Kunena Notice: Menu item /forum (Itemid=nnn) does not have Kunena Menu
15 years 5 months ago #64221 by freedomcoach
Hi Everyone:
I installed K1.6 on my test site. It seems to be working fine. However, I'm seeing one error message at the top of my forum saying "Kunena Notice: Menu item /discussion-forum (Itemid=55) does not have Kunena Menu.". I checked the menu item and do not see anything wrong with it. Any suggestions?
Sincerely,
Howard
15 years 5 months ago #64243 by xillibit
15 years 5 months ago #64306 by freedomcoach
Thanks, I fixed it.
Sincerely,
Howard
15 years 5 months ago #64309 by Requiem
Matias wrote: @ Requiem:
Please enable debug mode form Kunena and look if you get any notifications/information that may help you to find the issue.
Your problem sounds like you have issues with your menu, not Kunena itself. Did you change menu item in your main menu to be Entry Page as I told in few messages back?
I tried to upgrade 1.5.3 directly to 1.6.1 and problem with the menu resolve. Before that I tried to update 1.5.3 to 1.6.0 first, and then to 1.6.1 dev. Thanks
15 years 5 months ago #64414 by F0l2saken
I read that doc and copied the kunena menu into my main menu, and also did the same with entry page, still does this every time I edit the profile. I don't understand why kunena needs to tell me that every time, I don't want it in that menu, I'm just going to find that warning message in the code and delete it.
15 years 5 months ago #64417 by fxstein
F0l2saken wrote: I read that doc and copied the kunena menu into my main menu, and also did the same with entry page, still does this every time I edit the profile. I don't understand why kunena needs to tell me that every time, I don't want it in that menu, I'm just going to find that warning message in the code and delete it.
The issue is that the router found an error. First - it only shows the message to an admin, no moderators or users will see it. Second, it means that something is wrong or broken in your menu setup. When you run SEF this can mean that some of your SEF URLs will be wrong. Joomla happens to use the menu for all its SEF paths.
Deleting the warning is not going to fix that for you.
Time to create page: 0.320 seconds
