Question [Merged topic] Kunena Notice: Menu item /forum (Itemid=nnn) does not have Kunena Menu
15 years 5 months ago #74882 by Spartacus
Replied by Spartacus on topic Menu Error
I'm relatively new to Joomla and Kunena and now got an error (see below) for whicht I need help finding out the right things to do.
in hope for help
Spartacus
This is the error message, occuring at the top of the content area on entering any topic:
"Kunena Notice: Menu item /forum (Itemid=165) does not have Kunena Menu."
And this is my Kunena config report:
htaccess: Exists | PHP environment: Max execution time: 50000 seconds | Max execution memory: 40M | Max file upload: 20M
15 years 5 months ago #74884 by Spartacus
sorry for disturbing you. Found it with a search here.
Consider it solved ;-)
Spartacus
15 years 3 months ago #82020 by strangeoddone
Replied by strangeoddone on topic error?
I have this error:
Kunena Notice: Legacy menu item in /strange-odds-and-ends-forum (Itemid=39). Redirected to /forum (Itemid=69).
I don't run joomla legacy, and I don't know where this error is coming from. It happens everytime I click on the forum. Please help?
15 years 3 months ago #82040 by xillibit
Replied by xillibit on topic Re: error?
This not mean that you have legacy plugin, but that you have an old legacy item wich is still and it need to changed
Can-you put please your kunena report configuration settings ?
15 years 3 months ago #82106 by sozzled
strangeoddone wrote: I have this error:
If you had searched for "Kunena Notice: Legacy menu item" you would have turned up this topic. I have merged your question with a topic that will help you.
This is one of the reasons we really appreciate people putting the actual error message as the topic subject: it helps others who might also be searching about their problems. Using the subject "error?" is not very helpful. I would ask you to remember that in future. Thanks. ;)
Time to create page: 0.271 seconds
