Kunena 6.4.8 Released
Question [Merged topic] Kunena Notice: Menu item /forum (Itemid=nnn) does not have Kunena Menu
15 years 1 month ago #101 by sozzled
15 years 1 month ago #102 by WarLord
Replied by WarLord on topic item menu
I just got this when I deleted a post on my forum. whats it mean?
Kunena Notice: Menu item /logout (Itemid=24) does not have Kunena Menu.
15 years 1 month ago #103 by kuato
Replied by kuato on topic Re: item menu
Is this solved ? , I've installed kunena from scratch and it is generating weird menu items.
15 years 1 month ago #104 by sozzled
kuato: can you please explain (with pictures, perhaps) "weird"? Thanks.
15 years 1 month ago #105 by CoryPedersen
FreeThinker wrote: What seems to be the fuzz with this!? :P
Matias already gave the link to where this is explained:
=> docs.kunena.com/index.php/Customised_menus ]
It's so easy.....
1. Go to Menu Item Manager: Menus >> Kunena Menu
2. Edit Forum
3. Change Alias
Done! ;)
Thanks, FreeThinker! This was the simple explanation I've been looking for. Good grief; my feeble brain apparently couldn't recognize that Kuena has it's own menu system, which I know I've been told, but I never though to actually look for it in the Menu Manager until now. I simply changed the Forum alias here and all now appears to be well.
Thanks for spelling it out in simple terms!
Cory
15 years 1 month ago #106 by FreeThinker
15 years 3 weeks ago #107 by Yrezvani
I instal kunena 1.6.0 on Joomla 1.5.22 integrated with cb 1.2.3.
for some menus this message will appears on top of the forum template.
Kunena Notice: Menu item /searchforum (Itemid=79) does not have Kunena Menu
how can i fix it
15 years 2 weeks ago #108 by FreeThinker
In kunena background, click on the item "create menu"
and also you may take a look at this below:
It's so easy.....
2. Edit Forum
3. Change Alias
Done! ;)
15 years 1 week ago #109 by Spartacus
Replied by Spartacus on topic Menu Error
I'm relatively new to Joomla and Kunena and now got an error (see below) for whicht I need help finding out the right things to do.
in hope for help
Spartacus
This is the error message, occuring at the top of the content area on entering any topic:
"Kunena Notice: Menu item /forum (Itemid=165) does not have Kunena Menu."
And this is my Kunena config report:
htaccess: Exists | PHP environment: Max execution time: 50000 seconds | Max execution memory: 40M | Max file upload: 20M
15 years 1 week ago #110 by Spartacus
sorry for disturbing you. Found it with a search here.
Consider it solved ;-)
Spartacus
Time to create page: 0.301 seconds
