Important User profiles edit problem
I suspect the problems that you're having are something to do with the site template that you're using. We can eliminate that as an issue if we have access to the "edit user profile" area of your site. Thanks
KalleP wrote: Ok, here it is.
In your debug output I see over 100 queries related to jos_menu - the joomla menu. Something is wrong there (independent of Kunena) You menu structure is either HUGE or something is not correct. I have never seen a site run so many joomla menu queries.
KalleP wrote: Of course! Here it is:
Let me check - will be right back...
That accordion menu mod you are running seems to be the culprit of those countless queries. It is either configured incorrectly or its code is highly inefficient. Just FYI 100 queries just for that menu is 3 x that of Kunena 1.6 - so if for a menu you need to run so many queries - it will impact site performance quite a bit.
Can't tell you more without actually seeing the module.
Still looking into the javascript issue...
If you want to see my files:
mod_ojaccordionmenu
Not only does it seem to add 100 queries per page load, it also loads an old outdated jquery version from 2 years back and without the proper NoConflict mode declaration.
This is a great example of individual modules packaging up various versions of javascript that will collide with everything else. Exactly the reason why we decided to leverage Joomla for any such libraries.
If you where to install something like jomSocial (just an example) on your site, it too would be broken as you cannot load two different versions of the same javascript library on a single page.
I recommend you seriously look into
A. fixing mod_ojaccordionmenu
B. replacing it with something different
I've digging around because maybe there's something that can be added to the Wiki article I've been writing about Mootools and Kunena. FWIW, there might be some value in this item at the Joomla forum site: forum.joomla.org/viewtopic.php?f=304&t=283215&start=30
The evidence strongly suggests that the accordion menu involved in this test case is related to jQuery and that there's a conflict with Joomla's Mootools 1.2.4 library. The problem can be worked around by using a different menuing system, as fxstein has suggested, or by fixing whatever is wrong with the mod_ojaccordionmenu module.
