The Kunena team has announce the arrival of Kunena 6.4.9 [K 6.4.9] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
The Kunena team has announce the arrival of Kunena 7.0.1 [K 7.0.1] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Bug
[Problem assumed resolved - no response from user] Slimbox problem
Your Kunena template has the version of the slimbox, you need to check if a new version of your template is available or update by yourself the slimbox
You have enabled some kind of JS/CSS minifier. They usually cause a lot of troubles with many components (no idea why), so please try to disable the plugin and try if the attachments work without.
