- Thank you received: 9
Kunena 7.0.7 Released
This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question J! 1.6 + K 1.6 Upgrade error: unable to write entry
15 years 5 months ago #83976
by xreliable
Replied by xreliable on topic Re: Aw: J! 1.6 + K 1.6 Upgrade error: unable to write entry
FYI the menu issue looks to be related to a known J1.6 bug that was thought to be fixed:
joomlacode.org/gf/project/joomla/tracker...racker_item_id=21441
and others are having problems since Stable:
forum.joomla.org/viewtopic.php?f=615&p=2394854
- Thank you received: 2536
15 years 5 months ago #83983
by rich
Replied by rich on topic Aw: J! 1.6 + K 1.6 Upgrade error: unable to write entry
Hello xreliable,
you have a export data only from the table jos_menu. Please can you send as attachement for me? I would test upgrade with your menus. In table jos_menu there is no private dates from you.
But you can upload the file and insert. With the code "confidential" see only admins and moderators this file.
[confidential][attachment:1]C:\fakepath\jos_menu.sql.zip[/attachment][/confidential]
15 years 5 months ago - 15 years 5 months ago #83989
by Simiys
Replied by Simiys on topic Re: Aw: J! 1.6 + K 1.6 Upgrade error: unable to write entry
What to me do?
Last edit: 15 years 5 months ago by Simiys.
15 years 5 months ago #84055
by Simiys
Upgrade error 1.6.2 to 1.6.3
Подготовка установки ... OK
Распаковка com_kunena-admin.zip ... OK
Распаковка com_kunena-site.zip ... OK
Распаковка com_kunena-media.zip ... OK
Установка English (United Kingdom) языка ... OK
Установка Russian (CIS) языка ... OK
Установка плагина System - Kunena ... Error
Please . HELP!
Please . HELP!
15 years 5 months ago #85463
by skmliton
Replied by skmliton on topic Re: J! 1.6 + K 1.6 Upgrade error: unable to write entry
same problem I found. what is the solution
FAILED Uncaught Exception: Another menu item has the same alias in Root. Root is the top level parent
please help!!!!!!
please help!!!!!!
15 years 5 months ago #85479
by skmliton
I GOT THE SOLUTION!!I GOT THE SOLUTION!!I GOT THE SOLUTION!!
just find out the menu which you already created name or alias name "forum" . and delete the menu and empty from the trash. thats all
