- Forum
- Archive
- Kunena 1.7 and Kunena 1.6
- K 1.6 test reports
- K 1.6 test reports - Joomla 1.6 issues
- [Merged topic] J! 1.6 + K 1.6 - How do I restore my Kunena menu?
Kunena 5.1.15 Released (27 Oct 2019)
The Kunena team has announce the arrival of Kunena 5.1.15 [K 5.1.15] which is now available for download as a native Joomla extension for J! 3.9.x. This version addresses most of the issues that were discovered in K 5.1 and issues discovered during the development stages of K 5.1.
This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question [Merged topic] J! 1.6 + K 1.6 - How do I restore my Kunena menu?
8 years 7 months ago - 8 years 7 months ago #51
Replied by sozzled on topic [Merged topic] J! 1.6 + K 1.6 - How do I restore my Kunena menu?
Last edit: 8 years 7 months ago by sozzled.
The topic has been locked.
8 years 7 months ago #52
by miogoogle
Replied by miogoogle on topic [Merged topic] J! 1.6 + K 1.6 - How do I restore my Kunena menu?
Hello I have a little problem with my Kunena Forum. When I click on a section or topic of the Forum module menu and header disappear - I have reviewed many times assigned the correct forms for the menus and everything is correct but can not figure out where the problem is, can you help me please?
If You look it Clik Here
Please help me
Please help me
8 years 7 months ago #53
See the message before yours in this topic.
8 years 7 months ago - 8 years 7 months ago #54
by ambaqasah
Replied by ambaqasah on topic [Merged topic] J! 1.6 + K 1.6 - How do I restore my Kunena menu?
Hi all
I face the same problem. This was my site:
And here is my solution:
I play with .css file under this directory:
yourjoomlainstallation/components/com_kunena/template/default/css/kunena.default-min.css
by adding the following code:
color:#FFF; padding:0px 6px 0px;
to the style: #Kunena #ktab a (NOT #Kunena #ktab a span OR #Kunena #ktab a:hover...)
and after the property: background-color:#737373;
Save the changes and the page now should be like this:
Enjoy
Enjoy
Last edit: 8 years 7 months ago by ambaqasah. Reason: images doesn't appear
8 years 7 months ago #55
This problem has also been fixed in K 1.6.4 which will shortly be available to the public.
Yes, that's one solution. We advise all users to not directly edit the file kunena.default-min.css because this is a minified CSS file: see Minified CSS in the Wiki.ambaqasah wrote: I play with .css file under this directory:
../components/com_kunena/template/default/css/kunena.default-min.css
8 years 7 months ago #56
by ambaqasah
Thanks sozzled
I hope we will see the new version shortly
8 years 6 months ago #57
by ambaqasah
I install the last Joomla update (1.6.3) with last Kunena update (1.6.4)
But the problem still exist ?
Any idea what is the problem OR do I miss any thing (I updated the forum using Joomla Extension Manager)
This is my website link:
www.saudiclubmelbourne.com/index.php?opt...nc=latest&Itemid=408
Thanks in advance
Thanks in advance
8 years 6 months ago - 8 years 6 months ago #58
The purpose of this topic was to help people whose Kunena menu had "disappeared" or been rendered poorly with the new J! 1.6 templates. There were a few problems with previous versions of Kunena and these problems have now been fixed.
K 1.6.4 operates a little differently to previous releases of K 1.6 in the sense that, for new installations, K 1.6.4 creates the menu but leaves it unpublished. All that you have to do is to publish the menu and it should be all right again. However, for some people - those who upgraded from a previous version - they will need to look at the solution given at around msg #26 of this topic.
This is an old topic now. The topic has been archived. Rather than perpetuate the myth that K 1.6 is still "in testing" this topic needs to be locked. The problem has been fixed in K 1.6.4 for new installations of Kunena on J! 1.6.3 and that is a fact. The menu is there; you just need to publish it.
ambaqasah wrote:
I looked at the website ( www.saudiclubmelbourne.com/index.php/en/forum/recent ) and the problem is not that the menu is missing - which is what the purpose of this topic was intended to be used for - but the menu has been rendered unreadable because of the unique and unusual Joomla site template that is used on the problem site. It is not appropriate to hijack this topic for what is, basically, a design issue involving the user's site template. In this particular case, it is more appropriate to start a new topic in the Templates and Design category. There are several possible solutions in this particular case but let's talk about them in their own topic. Thank you.I install the last Joomla update (1.6.3) with last Kunena update (1.6.4)
But the problem still exist?
Last edit: 8 years 6 months ago by sozzled.
Forum Access
- Not Allowed: to create new topic.
- Not Allowed: to reply.
- Not Allowed: to edit your message.
- Forum
- Archive
