Solved Default Menu Item in Entry Page is pointing to missing or unauthorized menu item
12 years 6 months ago #11
by jabbott
Replied by jabbott on topic Re: Default Menu Item in Entry Page is pointing to missing or unauthorized menu item
I am having the same trouble. Dumping and recreating the database is not really an option for me though. I try to create the Kunena menu from the control panel and this is what I am getting as an error report:
500 - An error has occurred.
Another menu item has the same alias in Root. Root is the top level parent
Return to Control Panel
Call stack
# Function Location
1 JAdministrator->dispatch() /web/others/intranet/administrator/index.php:47
2 JError::raiseError() /web/others/intranet/administrator/includes/application.php:164
3 JError::raise() /web/others/intranet/libraries/joomla/error/error.php:215
Errors
The database row is empty.
Information
Backtrace
Call stack
# Function Location
2 JComponentHelper::renderComponent() /web/others/intranet/administrator/includes/application.php:153
3 require_once() /web/others/intranet/libraries/joomla/application/component/helper.php:156
4 KunenaModelInstall->deleteMenu() /web/others/intranet/administrator/components/com_kunena/admin.kunena.php:544
5 KunenaModelInstall->deleteMenuJ16() /web/others/intranet/administrator/components/com_kunena/install/model.php:1699
6 JTable->load() /web/others/intranet/administrator/components/com_kunena/install/model.php:1705
Information
Backtrace
Call stack
# Function Location
4 KunenaModelInstall->createMenu() /web/others/intranet/administrator/components/com_kunena/admin.kunena.php:545
5 KunenaModelInstall->createMenuJ16() /web/others/intranet/administrator/components/com_kunena/install/model.php:1392
6 JTable->load() /web/others/intranet/administrator/components/com_kunena/install/model.php:1577
Information
Backtrace
Call stack
# Function Location
Call stack
# Function Location
Errors
Information
Backtrace
Call stack
# Function Location
Information
Backtrace
Call stack
# Function Location
Information
Backtrace
Call stack
# Function Location
12 years 6 months ago #12
by jabbott
Solved. What I had to do is go into the shell of a menu that Kunena would create when I got this erorr message. It was in the menu manager, but it had no items in the menu. You have to create one. And, it is a two step process.
Create an menu item called "Entry Page" as the title.
Make the Menu Item Type "Entry Page" from the Kunena section of the selection box.
under the Required Settings dropdown.
Choose a random Default Menu Item. It doesn't matter what you pick.
Save and close.
Click on the Entry Page menu item you just created to edit it.
Go under the required Settings dropdown.
You should now have, as an option under the kunena menu section an option for Entry Page. Choose it.
Save and close.
Your error should be gone the next time you reload.
--ja
Save and close.
Save and close.
--ja
- climatebites
11 years 10 months ago #13
by climatebites
Replied by climatebites on topic Re: Default Menu Item in Entry Page is pointing to missing or unauthorized menu item
Same problem occurred after updating Kunena.
Unfortuantely, no luck with the method described above by Jabbott.
Has anybody else solved this?
This is a really annoying problem, that seems to be quite common!
11 years 10 months ago #14
Replied by sozzled on topic Re: Default Menu Item in Entry Page is pointing to missing or unauthorized menu item
G'day, climatebites, and welcome to Kunena.
The solution, offered by Jabbot 8 months ago, was for a much older version of Kunena. As far as we know, this problem no longer occurs in K 1.7.2.
This is not common. We have not received any reports about this problem for over 8 months. Your configuration report may assist us to help you solve your problem. Can you post it here, please?climatebites wrote: Same problem occurred after updating Kunena. This is a really annoying problem, that seems to be quite common!
Time to create page: 0.519 seconds
