Question How do I enable quick reply?
This is my setup now...
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 256M | Max file upload: 55M
board_title Forsforum board_offline 0 board_ofset 0 offline_message <h2>Forsforumet är för tillfället inte tillgängligt.</h2>
<div>Kolla här snart igen!</div>enablerss 1 enablepdf 1 threads_per_page 40 messages_per_page 15 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template default showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 imageprocessor gd2 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 200 allowfileupload 1 allowfileregupload 1 filetypes txt,doc,xls,pdf,docx,xlsx,html,htm,eps filesize 1024 showranking 1 rankimages 1 avatar_src fb_profile pm_component userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 10 showpopsubjectstats 1 popsubjectcount 10 usernamechange 0 rules_infb 1 rules_cid 1 rules_link www.kunena.com/ help_infb 1 help_cid 1 help_link www.kunena.com/ showspoilertag 1 showvideotag 1 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access communitybuilder integration_login communitybuilder integration_avatar communitybuilder integration_profile communitybuilder integration_private none integration_activity communitybuilder boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Please upgrade from K 1.6.0 to K 1.6.2. I think that will help with your problems.
Also, you might find it worthwhile to upgrade the Kunena Latest module, too.
xillibit wrote: Hello,
You have something which load Mootools 1.1 which doesn't work with kunena, kunena needs Mootools 1.2.x :
Code:<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/mootools/1.11/mootools-yui-compressed.js"></script>
I don't know what is loading this, but you try to disable all third modules and plugins, re-enable them one by one to see which one need to be removed.
I'll try this approach as well, thanks for the tip.
sozzled wrote: Thank you. It's nice to get feedback.
OK, I'll try that - now I have lots of things to try, thanks guys!
I realize its a good idea to upgrade to 1.6.2 on my main site as well. But I found that the included Swedish translation needs a lot of work. I can give it a try but I don't know what I need to do to share the results with others.
First I installet 1.6.2 on my test site. That didn't help, then I disabled alla plugins and modules as suggested. This resolved the problem and when enabling the plugins one by one I found that "System - Google Ajax library" was causing this.
Then I tried to disable this plugin on my main site but it didn't help. I then figured that it was the combination of Kunena 1.6.2 and disabling the plugin that was the key. But upgrading to 1.6.2 wasn't enough. I had to look for more conflicting plugins and found that "System - myApiConnect" also needed to be disabled.
Thanks for all help
- vientogris
I thought I solve my problem before but I'm now with the same problem.
Now I can't see the bbcode here, in your kunena forum!! I'm going crazy. I have enter in this support forum with firefox and ie and I can't see it.
Maybe there is a problem with my eyes :pinch:
Well, I have updated my forum two weeks ago and my users don't report me any problem.
In a local copy on my computer now is working fine, I don't understand nothing.
<script type="text/javascript" src="/includes/js/joomla.javascript.js"></script>
<script type="text/javascript" src="/plugins/system/mtupgrade/mootools.js"></script>
<script type="text/javascript" src=" www.elmultiverso.com/components/com_kune...ed/js/mediaboxAdv.js ">
<script type="text/javascript" src=" www.elmultiverso.com/components/com_kune...lt/js/default-min.js ">
<script type="text/javascript" src=" www.elmultiverso.com/components/com_kune...s/kunena.poll-min.js ">
<script type="text/javascript" src=" www.elmultiverso.com/components/com_kune...ult/js/editor-min.js ">
<script type="text/javascript" src="/media/system/js/validate.js"></script>
<script type="text/javascript">
- vientogris
:S
This is really strange
Edit: There's something wrong with my computer, my firefox or something. I'm in another computer and I see the bbcodes in my forum, your forum... why?
