Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question [Merged topic] When the number of views or replies is greater than 9999 ...
15 years 3 months ago - 15 years 3 months ago #70243 by pequeno74
Nobody has seen this?
Point and K apperars...
Appears in the views or replies.
Thanks.
Last edit: 15 years 3 months ago by pequeno74.
15 years 1 month ago - 15 years 1 month ago #80725 by gjhvs
I have just installed Kunena 1.6.2. and love it so far :)
I have a very big and busy forum so a lot of topics are viewed more than thousands and thousands of times.
When you look at a category index of the forum you can see that in the column 10.000 views for instance.
I do find the way the views are presented a bit strange. If you look at the file attached in the column 'bekeken' (=views in Dutch). Look at the first topic, it is viewed 61.37duizend (duizend=the word thousand in dutch).
I find that a bit strange. I'd rather have it displayed just in numbers like 61.372 (and not with the word 'duizend').
I have looked in the admin but can't find anything... Is this changeble? And if yes, how can I change it so the views will be like 61.178 / 10.890 again?
Hope someone can help :)
Kind regards, GertJan
Last edit: 15 years 1 month ago by gjhvs.
15 years 1 month ago #82653 by gjhvs
A little bump... can someone help me with this?
15 years 1 month ago #82655 by 810
Hi gert-jan,
do you have a link to your site.
thnx
15 years 1 month ago #82656 by gjhvs
Here is the link to the forum: www.madonna.nl/site/forum.html
15 years 1 month ago #82659 by 810
i think its a gavick template problem, first can you try to use the kunena default template. if its works, then your own template isn't working perfect, But i also see that he always load the ie7 template. there is the proplem.
regards 810
Time to create page: 0.327 seconds
