Kunena 6.2.6 released
Merged [Merged topic] What do I need to do to get private messages working on my forum?
What component do you have installed for Private Message ?
I need a seperate component for this to work? Ok, which one do you recommend?
Regards,
Robert
UddeIm is good choice, if you are using Jomsocial this integrate a pm system in it so you can use it.
Already up and running!!!!
You just have to watch out when creating lists! The default delimiter did not work for me, but after I changed it to ';' it was fine.
"UddeIm is good choice" is a perfect understatement. Works perfect with KUNENA, integrates very nicely into my site and is very logical as far as the setup goes.
- LukeDouglas
- Thank you received: 1
If there isn't a functionality like this, it 'really' needs to be implemented.
- snilloconator
- Premium Member
- aka snilly
extensions.joomla.org/extensions/communication/pms/3206
This is an option in Kunena's backend under integration in the config section.
- frenostanco
- Junior Member
- Thank you received: 3
(Yes, I will upgrade to 1.6.4 asap)
Hello to everybody!
- frenostanco
- Junior Member
But... Uddeim is not a bundled feature coming with Kunena, I'm right? Is a third-part component. :dry:
Do you suggest me to install? It will work without problem?
I have a further question: I see here, in Kunena forum, that PMs are available. From where this feature came? From a third-part component (Jomsocial?) or something like Uddeim?
Hello to everybody!
Yes.frenostanco wrote: Thanks Smirnov.
Works without problems. You can be registered at my forum and to look work uddeim.Do you suggest me to install? It will work without problem?
No, on kunena.org - not uddeim.I have a further question: I see here, in Kunena forum, that PMs are available. From where this feature came? From a third-part component (Jomsocial?) or something like Uddeim?
