Kunena 6.2.6 released
Question High CPU and memory used caused by Kunena Forum
12 years 6 months ago - 12 years 6 months ago #1 by brenden
Hi all,
Long time user of Kunena and love it but a relative noob in terms of extreme techy detail. Recently over the last week we've had performance issues where our server CPU and memory use has spiked dramatically.
According to our host their server is OK and they pointed to Kunena forum causing the issue. They suggested something might be keeping data in cache.
Attached are screen shots of cpanel showing CPU and memory use.
Anyone seen / experienced this? Is there a way to disable cache for forum?
Any insight is greatly appreciated!
Last edit: 12 years 6 months ago by brenden.
12 years 6 months ago #2 by xillibit
Can-you put here your Kunena report configuration settings ?
12 years 6 months ago - 12 years 6 months ago #3 by PJFonseca
We at androidPT.com have the same problem.
The configs:
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 100M
Joomla default template details : ja_purity | author: JoomlArt.com | version: 1.2.0pt | creationdate: 12/26/07
Kunena default template details : Example Template | author: Kunena Team | version: 1.6.4 | creationdate: 2011-05-07
Third-party components: UddeIm 2.0
Modules: Kunena Latest 1.0.47
Last edit: 12 years 6 months ago by PJFonseca.
12 years 6 months ago - 12 years 6 months ago #4 by brenden
Report below - Apologies for not including originally:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 4M
Joomla default template details : stormlab | author: LineLab.org | version: 1.0.0 | creationdate: 29.4.2011
12 years 6 months ago #5 by PJFonseca
Any thoughts on this?
12 years 6 months ago #6 by Matias
Memory usage probably comes mostly from apache processes -- the more users you have, the more memory it takes. Disabling (or having at most 3 seconds) keepalive setting in Apache usually helps to keep memory usage lower.
CPU usage may be caused by anything and you really need to know which processes are taking the time.
12 years 6 months ago #7 by brenden
Some more info: Our host claims it could be cache building up.
We did a complete upgrade to Joomla 1.7 and latest Kunena. First few days it was fine, then after 2 days back to high memory and CPU use again.
12 years 6 months ago #8 by Matias
Kunena 1.7 doesn't cache anything, so it's not Kunena cache.
We are now preparing Kunena 2.0 beta release. Kunena 2.0 has been optimized so, that it works with less resources, especially in huge forums.
12 years 6 months ago #9 by PJFonseca
Nice... lets wait for it.
Time to create page: 0.440 seconds
