Kunena 6.2.6 released
Merged If you are having problems with Kunena, please read this first
I am looking at some of the info & articles, per your direction, and find that I can't glean how to correct jquery using mootools. I'm sure that I'm missing something obvious...
Ken
You are correct. This is better explained in Javascript and Kunena and I invite you to read what has been written before. In many of the cases reported on this forum the question could be simply summarised as My Joomla template is making a mess of Kunena and I also invite you to read that article too.kriead wrote: Thank you for your reply. My understanding is that jquery is a java-script tool ...
jQuery Javascript conflicts with Joomla Mootools can be resolved. There is much information written on the internet (including references in msg #1 of this topic that we continually refer to) to help people who have jQuery-based Javascript. Sometimes these things are easy and sometimes things aren't so easy. As far as Kunena is concerned, the decision was taken about 2 years ago to move away from jQuery and use Mootools because that was the strategic direction being taken by Joomla.
Joomla, as we all know, is not three-mouseclicks-and-hey-presto-instant-website. Joomla is "serious" webcraft. Many of the problems that people encounter, however, begin with the strategic decisions that they need to take when they build a website, the most important one of which is "What's the most important ingredient I need, on my site, that yields the maximum value that visitors will obtain when they visit it?" When people focus, first and foremost, on that strategic question, and deal with the implementing a mix of software that achieves those objective, other issues (e.g. what the site looks and "feels" like) usually fall into place. Perhaps another way of saying this is Which came first? The template or the forum?
Because www.kunena.org is a community-driven, self-help forum, sometimes it's not practicable to address every unique combination of software that people have chosen. In these cases, I suggest that people return to the basics: start with a known, working "no-frills" Joomla installation, add Kunena first, and then add the other things you may need (making sure that, after adding each new extension that you check to make sure you haven't broken something in Kunena). Working backwards from when you have problems after you've installed Kunena as one of the last extensions, is sometimes quite difficult (especially for new users of Joomla) and that's why we often have questions, like yours, asked repeatedly.
Obvious? Not necessarily. jQuery is not always the cause of every problem (as you will see from reading the Wiki); it's just one possibility.
Does not display the field profile of the forum?
Button to save, back, cancel - are working.
In version 1.7.1 of these problems are not seen
Tested on Joomla 1.5.25
Sorry for my English.
I bet those problems would be seen on your site if you use K 1.7.1 (just as I would be willing to bet that these problems would be seen on your website if you used any version of Kunena all the way back to K 1.6.0). The answer to your problem is in msg #1 of this topic. You have a Javascript library conflict with Mootools.lev wrote: In version 1.7.1 of these problems are not seen
You may have another site, somewhere else, running K 1.7.1 (that you haven't upgraded yet) where you don't have these issues - and that's my guess - but K 1.7.2 is not the cause of the problem.
You're right because of it System - Mootools Upgrade.
Only in the admin panel he had been set, but in fact, plugin files have been removed.
It can be seen when I rolled back the database but pokakoyto reason vostanovil remote plug-in, eventually downloaded the plug-in and hand-poured, via FTP.
Now it works!
extensions.joomla.org/extensions/core-en...ements/scripts/14643
I just installed 1.7.2 on the Clarion theme from rocketthemes.
Everything seems to work fine except that i can´t edit the user profile i kunena forum.
Any ideas what could be wrong?
Best regards
Miguel
- Jiminimonka
- Elite Member
- YBAS!
Go into Clarion template settings, Advanced and turn off Build Title Spans. That should fix it.
Truly amazing! It worked
I just have to ask... Is there a way to have the function enabled and sill be able to edit the profile?
The function is kind of cool.
Best regards
Miguel
- CheechDogg
- Premium Member
I have also asked over at RT's forums and I have not gotten and answer. Sorry.
