Kunena 6.4.8 Released
14 years 9 months ago #89888 by justmebg
I am having the same issue - no attach file window opens, global Joomla settings do not repress attachments. This is important for my forums as I am using them for support (much like this one) I've tried both a custom 1.6 template and the default - doesn't change anything.
Joomla default template details : impacto | author: Casey Lee | version: 1.8 | creationdate: 09/16/10
Kunena default template details : Adrine - Kunena 1.6 Template | author: TemplateKunena Team | version: 1.6.2 | creationdate: 2011-01-25
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.4) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.2)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.2) | Kunena Search: Enabled (Version : 1.6.2) | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.6.2) | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.2)
14 years 9 months ago #89889 by sozzled
justmebg: which of these issues are you having difficulty with that seems to be the one that you are using this topic for:
  1. No Attachment Browser
  2. No Local Photo upload
  3. Insert Video URL not working
In what way(s) are you having a problem?
To clarify your question further, are you not getting the "file open" dialog appearing when you click the Browse button when you try to upload an attachment or a photo (image)?
The insert video issue is unrelated to these other things, I think.
Further, I recommend that you read how to properly setup Joomla SEO .
I would also recommend that you disable "integration activity" unless you have a specific need for this feature.
The following user(s) said Thank You: justmebg
14 years 9 months ago #90182 by Gatekeeper
Replied by Gatekeeper on topic a few problems
1.
Ive just installed kenuna 1.6.3 forum on our 1.5 joomla website, its great BUT a few issues
Firstly the "mootools upgrade plugin" stopped the "a menu item working that used javascript" this particular component had to be un installed which was a shame as it was a major part of our site , but before I uninstalled I disabled the mootools upgrade plugin and it worked again
So I had to choose between having the new forums with the upgrade plugin for mootools or loosing the component our site used
2.
We have no editor on our forums, we have smilies but they only work by placing the code in the post
everything else is fine
Just wondered if anyone could help thanks
14 years 9 months ago #90212 by sozzled
G'day, Gatekeeper, and welcome to Kunena.
Please read msg #1 in this topic. Thank you.
14 years 9 months ago #90265 by Gatekeeper
thanks ,
I read it , and applied some changes and it works now, thanks
Seems just putting the new mootools plugin first made it work
thanks gb
14 years 9 months ago #90277 by da21f8a1397f7a5fc3ca78b7
htaccess: Exists | PHP environment: Max execution time: 10 seconds | Max execution memory: 24M | Max file upload: 1500K
Joomla default template details : blueish | author: Juergen Koller | version: 1.0 | creationdate: 04.12.2010
Ran into trouble when tried to use Kunena with a nice template I have found: BLUEish. There's no trouble regarding forum layout, colors ans so on.
The trouble is when I try to edit my profile, clicking the "Save" button gives no effect. "Cancel" works right (or how is that button called, sorry, using russian translation... A button to cancel profile change).
Changing template helps! So the trouble should be in template itself, but... Where could it be?
I had this trouble on a test installation of Joomla. Got tired of all that stuff, purged my DBs and filesystem and installed fresh Joomla, BLUEish and Kunena back. Exactly the same...
Using Joomla 1.5, if anyone interested.
Time to create page: 0.356 seconds
