Merged If you are having problems with Kunena, please read this first
- CAVEGRAFFITTI
Forbidden
You don't have permission to access /forum on this server.
Additionally, a 500 Internal Server Error error was encountered while trying to use an ErrorDocument to handle the request.
- Panayiotis
I have read previous threads on the Mootools issue, and have managed to install a plugin called 'Disable Mootools'. Now I'm able to see and click on the 'Edit' button [previously I couldn't even do that], but now all menus/buttons are grey - unclickable. After enabling Mootools again I went back to the previous state where I can't even see the 'Edit' button.
Is there another setting in Kunena's configuration menu that I need to configure?
I get this tip from Kunena testers, when I first time used RocketTheme templates.
- Panayiotis
However, you suggestion made me think whether Kunena works best with specific templates.
Any ideas anyone?
- CAVEGRAFFITTI
- Panayiotis
I downloaded the Mootools upgrade plugin, installed, and enabled. Now all features work!
For some reason the Mootools upgrade plugin did not install as part of the Joomla 1.7 installation.
The plugin can be found here:
www.jseblod-cck.com/en/download/11975-mo...-upgrade-plugin.html
By the way, I also disabled the plugin "Disable Mootools"
regards 810
- NielsVolman
Tried to fix it using jomsocial, but that doesn't allow the use of signatures which I would like.
I'm using Joomla 1.5.23 with Kunena 1.7.
When I don't use Jomsocial and tried turning the mootools on/of and that makes the "EDIT" button clickable/not clickable. However still can't edit the details like avatar, etc.
