Kunena 6.4.8 Released
14 years 9 months ago #41 by ahken
Clear and concise and it worked for me too!
14 years 9 months ago #42 by ashquadir
What is your rate to fix some thing like this?
You may email me directly at [email protected]
Thanks.
14 years 9 months ago - 14 years 9 months ago #43 by sozzled
See PM
EDIT: Problem solved. User disabled GTranslate module and Kunena then worked.
Last edit: 14 years 9 months ago by sozzled.
14 years 9 months ago - 14 years 9 months ago #44 by gvvampire
Replied by gvvampire on topic Profile edit problem
Hi there,
Iam using the latest forum but when i try to edit the profile i take the following picture.
There is nothing to edit...!!!
I have also enable the moo plugin and i am using the 1.5.22 joomla.
Could you please inform me what must i do?
Thank you for your time.
Last edit: 14 years 9 months ago by gvvampire.
14 years 9 months ago - 14 years 9 months ago #45 by pedrox
Kunena 1.6
Not show the options for editing ...
Last edit: 14 years 9 months ago by pedrox.
14 years 9 months ago - 14 years 9 months ago #46 by sozzled
gvvampire and pedrox: Please see msg #1 in this topic.
The following user(s) said Thank You: pedrox
14 years 9 months ago #47 by wabrix
Hello!
I'm runnin K 1.6.3 on J!1.6.1
At some point toolbar has gone broken(attacked image showing the issue) and smilies have stoped working, they(smilies) do appear, but are not clickable.
Unfortunately i noticed this issue only now and can't track if this apeared after adding some new modules to the site.
Have tried switching/reseting templates and settings of the site and Kunena to state there was no issue, but no luck up till now :(
tested on FF,Chrome,IE8/9,Opera
my config report on next post below
14 years 9 months ago #48 by wabrix
my config report:
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 96M | Max file upload: 24M
Joomla default template details : beez_20 | author: Angie Radtke | version: 1.6.0 | creationdate: 25 November 2009
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: The file doesn't exist comprofilej.xml ! | Jomsocial: Disabled or not installed | UddeIm: The file doesn't exist uddeim.j15.xml !
14 years 9 months ago - 14 years 9 months ago #49 by sozzled
G'day, wabrix, and welcome to Kunena.
Please read msg #1 in this topic. Thank you.
14 years 9 months ago #50 by wabrix
thnx, that fixed it
cheers
Time to create page: 0.351 seconds
