Kunena 6.2.6 released
Merged If you are having problems with Kunena, please read this first
Disabled and working like a dream. Now I just have to figure out if I upgrade JCE will it work?
Thanks!
I also do not have any board code either for bold text etc
This is a screenshot of my Boardcode section:
And this is yours:
Could you please explain why my emoticons do not work and I do not have and board code displayed
Thank you
PS. I am using Kunena v1.7 and Joomla v1.5.2.3
<script type="text/javascript" src="/components/com_gantry/js/mootools-1.2.5.js"></script>
<script type="text/javascript" src="/media/system/js/mootools.js"></script>
Once within the com_gantry folder and again in the media folder.
I renamed mootools.js in the media folder so that it could not load and everything now works.
Do you know why this has happened?
I have recently installed and set up Jom Social 2.2.5 on my site and everything worked fine. I then installed and set up Kunena forums on our site with the proper integrations. Now it seems like the status update in profiles and such is not working any more. When I hit quick reply it opens in a new page. Should it do so? In the administrator panel the popups for jomsocial does show up, empty. Any idea what it might be? I dont. The popups in administration panel did work, and the last time I remember touching them was before I installed Kunena 1.7. I run Joomla 1.5.23.
I read this topic that was an issue with 1.5.5:
www.kunena.org/forum/139-solved-or-prior...-working-in-155#2666
But that was not the issue.
The page could be viewed here:
prosjekt.tronderbataljonen.com
Username: Test
Password: 123456
regards 810
- etkritikonspoudon
- Senior Member
- Thank you received: 7
Maybe this is more proper to ask over at Rockettheme's forum? How can a Kunena developer solve the problems that Gantry may be causing?makuk wrote: 5 days and no reply - does anyone actually give a crap in here !!!!!!!!
