Merged If you are having problems with Kunena, please read this first
Yes, the problems with JA_Purity II's menu system are well-known. The last time I tested JA_Purity II, I was able to make Kunena work if I used one or two of the menu options; the rest of the options blow-up Joomla's Javascript Library (Mootools).
The answer to your question is in msg #1 in this topic.
I don't know what you've read or what information you've received elsewhere but the facts you are looking for are given in the links in msg #1 in this topic.
We would dispute most of the so-called "facts" that you quoted in your post.
- cellardoor_ncx
Most other forum software for Joomla uses these recently updated Mootools libraries, too. You will probably have to go outside Joomla for a "bridged forum" solution if Mootools 1.1 where you need to stay.
90% of the problems that people have with K 1.6.x are mostly caused by using old, unsupported Joomla site templates.
- cellardoor_ncx
I would not waste my time with JA Purity II; I mean, I spent about 45 minutes with it one day, got it to work with K 1.6, said to myself "big deal" and then I disposed of it. People an over-agonise about the choice of site template; at the end of the day you have to ask yourself what's more important to you: functionality or eye-candy? Good ol' JA_Purity that comes free, out-of-the-box with J! 1.5.23 works just as well and, to the untrained eye, isn't that much different to JA Purity II. The original JA_Purity is still the best ... and it works with Mootools 1.2.5. It's a two-minute fix-it.
I have just set up a Joomla site (1.5)
I have installed a RocketTheme template, if that helps diagnose the issue.
I installed Kunena today, version 1.6.5.
I have the default template installed.
I have found that if I go to Profile and click the edit button, the panel appears, but there is no information and none of the tabs work.
I have enclosed a screenshot to show the situation.
Can anyone give any solutions?
*** Found that there is a plug-in called "System - Mootools Upgrade" if it is turned on the info and tabs work, but the Edit button disappears. If it's switched off then the edit button works but no information is there. The version is: Mootools 1.2.5 ***
Thanks in advance
Please see msg #1 in this topic.
Could you please be more specific about what it is that you have enabled, please? Thank you.infinart wrote: I have it enabled ...
