Kunena 6.2.6 released
Merged If you are having problems with Kunena, please read this first
Something to do with your server provider?(if everything other things are correct)
FYI, it's much more helpful to you if you don't edit your K 1.6 configuration report. Certain parts of the report provide us with details that can help you. Some of that information is encased in
i dont know how to fix it and im really lost.
Please see msg #1 in this topic.
That's good to know but that is only 0.1% of your problem solved. The answer is not whether you have Mootools 1.2.4 installed or enabled, the answer lies in finding out what other Joomla extensions you have installed that are clobbering Mootools 1.2.4 and dealing with them. Please read the links in msg #1 in this topic.i have check my mootools and my current version is Mootools 1.2.4
Everything works great when i switch to the default template. i must have missed something somewhere.
k so ive been looking through my site with firefox with the firebug plugin and found this,
MooTools.More={version:"1.3.0.1
there is nothing about mootools itself, just that.
im back to the lost stage..
also found this with firebug
$(document.body).adopt is not a function
[Break On This Error] var Slimbox=(function(){var F=window,n...loop&&(g.length>1);return b(O)}}})();
if that has anything to do with it. if not then just disregard
also i have noticed that my theme is for version 1.6.0, how do i update it to make sure that it is not the issue.
it was Slimbox in the initialize.php file. just // it out and it works great now.
when i edit a topic, kunena show a wrong bb code like
when i edited my topic, it show
please help.
