Merged If you are having problems with Kunena, please read this first
12 years 10 months ago #191 by sozzled
G'day, HSA, and welcome to Kunena.
Please see msg #1 in this topic.
The following user(s) said Thank You: HSA
12 years 10 months ago #192 by HSA
Hi there sozzled!
Thanks for the links.
Mootools ok (Upgrade)
JQuery ok (loads after mootools)
Will try some of the other options suggested by users.
12 years 10 months ago #193 by tonytong
Replied by tonytong on topic help me
dear all
i have use install kunena when i use test menber login
i cant change my profile and update my photo
i have po the error image i use red line
how can i use it?
install which component or mole ?
please help me
thank all
12 years 10 months ago #194 by sozzled
G'day, tonylong, and welcome to Kunena.
12 years 10 months ago - 12 years 10 months ago #195 by iOverclock.com
I dont have any "Boardcodd" options, like boald letters, etc. Only emots. The space is there but no editing ability on my user editor...
Whats up??
Also my Attachments wont give me the option to Remove or Insert attachment.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 1024M | Max file upload: 5M
Joomla default template details : new_york_creative_architect_4 | author: Alex Athineos | version: 2.0 | creationdate: 2011-05-28
Kunena default template details : Euro-BBlue | author: Mizunga | version: 1.6.1 | creationdate: 2010-12-20
Third-party components: CommunityBuilder 1.4 | UddeIm 2.3
Third-party SEF components: sh404sef 2.2.5.964
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | Kunena Search 1.6.2 | Kunena Discuss 1.6.4
Modules: Kunena Latest 1.6.4 | Kunena Stats 1.6.2 | Kunena Login 1.6.4 | Kunena Search 1.6.4
Thanks...
Last edit: 12 years 10 months ago by sozzled. Reason: Reveal K 1.6 configuration report in message
12 years 10 months ago #196 by sozzled
12 years 10 months ago #197 by Baralak
Replied by Baralak on topic Domready Not Firing
Greetings,
A few weeks ago I had a server crash and had to move several of my sites to another server. When I did, one of my sites developed a problem when you go to the Kunena Forums it pops up the MooTools Domready event never fired box in IE. I did read in detail everything having to do with JS on your link, but still can't seem to correct the problem. I have several Joomla sites and all of them are using Kunena and they are on the same server, this is the only site that is giving me problems.
It is using Kunena 1.6 with Joomla 1.5 Here is the Config Report:
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : rhuk_milkyway | author: Andy Miller | version: 1.0.2 | creationdate: 11/20/06
Third-party components: UddeIm 2.2
Modules: Kunena Latest 1.6.2
12 years 10 months ago #198 by 810
Replied by 810 on topic Re: Domready Not Firing
Please try to disable some plugins, it seems like a conflict.
regards 810
12 years 10 months ago #199 by sozzled
12 years 10 months ago #200 by mattc908
So basically when any of my users (self included) go to edit their profiles it comes up with the following lines of text: user account | profile informaiton | avatar image | forum settings | save | cancel...
The only two things you can click on are: Save and cancel, I'm not sure why this is happening?
htaccess: Exists | PHP environment: Max execution time: 600 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : rt_nebulae_j15 | author: RocketTheme, LLC | version: 1.5.0 | creationdate: April 28, 2011
Time to create page: 0.560 seconds
