Kunena 6.4.9 & Kunena 7.0.1 Released
The Kunena team has announce the arrival of Kunena 6.4.9 [K 6.4.9] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
The Kunena team has announce the arrival of Kunena 7.0.1 [K 7.0.1] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Sticky [Merged topic] How do I restore my Kunena menu?
15 years 2 months ago #71224 by fairwea1
Replied by fairwea1 on topic Kunena Menu Missing
My Kunena menu seems to have disappeared somehow. (index/recenttopics/newtopics....)
I'm guessing I clicked a button to turn it off somewhere but can't find it again.
Thanks,
Eric
The topic has been locked.
15 years 2 months ago #71237 by fairwea1
Replied by fairwea1 on topic Re: Kunena Menu Missing
Never mind! I deleted Kunena Menu! :blush:
15 years 2 months ago - 15 years 2 months ago #71359 by Elnablo
I am using newest JOOMLA & KUNENA. I have a really strange effect,
that the menubuttons in my Tab menu (INDEX, Recent Topics, etc)
above the forum just disappear.
If I set the moduls parameter to "Vorgängerversion - Hotizontal" everything
works and the menü is displayed at all times. Just looks really :sick:
"Vorgängerversion - Hotizontal" means something like "Previous version - horizontal"
in english.
Read somewhere, that System - Mootools should be upgraded, but that does
not help.
Thanks in advance for your help,
Robert
PS: Have tried 5 other templates, no difference!!!
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 80M | Max file upload: 8M
Joomla default template details : wds_car_desing_13 | author: www.templatki.com | version: 1.0 | creationdate: 2010-04-23
Last edit: 15 years 2 months ago by Elnablo.
15 years 2 months ago - 15 years 2 months ago #71372 by Elnablo
As far as I can read up in this forum, this is supposedly a mootools problem.
Well, I don't believe that to be so, beause the BBCode buttons of the editor do work and my
editor looks and works just like the editor here on site. If I read up correctly, this would
not be possible with the wrong mootools installed.
Also, the menu tabs do show sometimes and then I click into a topic and they are gone.
Using the back-arrow in the browser moves me back up, and the tab menu magically reapears.
So I'm betting there is a tiny error somewhere in the KUNENA code, right? If it would
never work under KUNENA, than I would believe the mootools theory. But since the tab
buttons do show up on certain pages of my KUNENA forum, it has got to be a coding error
or "undokumented feature". :ohmy:
Seems logical to me, right?
15 years 2 months ago #71427 by sozzled
The Kunena menu is unrelated to Mootools. The Kunena menu is just a Joomla menu. See Customised Menus in the Wiki for further information.
The latest version of Joomla is J! 1.5.22.
To re-establish your Kunena menu, use the Create Menu option on your Kunena control panel.
15 years 2 months ago - 15 years 2 months ago #71466 by Elnablo
Maybe I didn't explain myself correctly.
See the foto below, that's the best I can do. I did have the large
Buttons for a while, but they don't work everywhere. For instance
they would just disappear, as soon as I clicked on a topic.
As fas as I can tell, it is a problem with KUNENA, because how else
can it be explained, that the buttons just disappear when changing
to a different part of KUNENA?
Using the very "ugly" buttons below, I at least don't loose my menu :sick:
along the way. Sure isn't pretty though!! So as soon as I change the
modul parameter to "List", I get a mess.
I can set up an example for you if you like. Will install 1.5.22,
as I am still on 1.5.21. 1.5.22 did not change anything.....
Also the "Mark all as read.." does not work properly. The text
only appears, when the mouse is moved across the button.
Thanks for your help,
Robert
[attachment:1]Kategorien - Main11 Forum-1.jpg[/attachment]
Time to create page: 1.338 seconds
