Merged [Merged topic] How do I restore my Kunena menu?
- kunenamies
My first post here ever and it has to be a possible bug Tried finding the answer from the forum but could not find this topic. If it has been solved then I am sorry for using the bandwidth...
I have noticed one strange thing happening when you enter the same Kunena Forum topic either via Kunena Discuss or via Kunena Forum. So I have an article that can be commented (Kunena Discuss enabled for that category and linked to a Kunena Topic). If enter the Kunena Forum and the topic by selecting "Discuss this article in the forums..." I get to the right place in Kunena but there are no Kunena menus. On the other hand, if I go to Kunena Forum and browse to the same topic that way I do have the Kunena menus. The difference seems to be the links used (I have SEF on):
Kunena Discuss generated link: www.domain.com/en/component/kunena/8-category-name/2-topic
Kunena Forum link: www.domain.com/en/forum/8-category-name/2-topic
One uses the words "component/kunena" and the other simply "forum" in the path. Is this a bug or is this how things are supposed to work?
Getting around this puts you back to the age old Joomla problem: How to generate menus for links that are dynamically generated without a lot of unnecessary work...
I have the latest J!1.7, Kunena Forum 1.6.5 and the latest Kunena Discuss 1.6.4 so I should be pretty much up-to-date with everything relevant I guess.
Anyways, thank you for great work and component(s) the whole Kunena team!
Let me see if I understand your question properly. You've followed the guide to creating a Kunena menu (as discussed in many sticky topics in the K 1.6 and K 1.7 Common Questions category or by referring to the "Kunena menu issues" on the FAQs tab above).
To be sure that I completely understand your question properly, and to be sure that this problem you're having is directly related to the Kunena Discuss plugin, are you claiming that you can see the Kunena menu when you access your forum from a menu item but the menu disappears when you go to the forum, somehow, as the result of making a comment on a Jooma artilce? Have I correctly summarised your question?
It sounds to me like you have a problem with the way that you've set up your Joomla menu. Your configuration report will assist in answering those questions.
- kunenamies
Kunena Forum as such works fine when I enter it by selecting the Kunena menu. I see all Kunena menu items and the forum works as it should. I can go to the topic that has been selected for Kunena Discuss to allow quick commenting directly from the selected articles (categories) and they work just fine and all Kunena menus work as they should.
However, if I go to an article that somebody has commented and I now see the link "Discuss this article in the forums" and I click that => the system takes me to the right place (i enter Kunena Forum and I see the topic) but I do not see the Kunena main menus at all.
I think I have followed the guidelines but I will double check tomorrow.
And you are right: This might not be a Kunena Discuss issue at all. It just sounded like a logical place to start.
The config is attached and thank you so much for looking into this...
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 64M
Joomla default template details : my_domain_template_1 | author: My Domain | version: 2.0.4 | creationdate: 01-21-2011
board_title My Domain board_offline 0 board_ofset 0.00 offline_message <h2>The Forum is currently offline for maintenance.</h2>
<div>Check back soon!</div>enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 3 shownew 1 jmambot 1 disemoticons 0 template aphotic-II showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 42 rtewidth 470 rteheight 200 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 0 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 0 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 1 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 100 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 1500 imagewidth 1500 imagesize 1000 allowfileupload 0 allowfileregupload 1 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 5000 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 0 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 1 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 3 showpopsubjectstats 1 popsubjectcount 3 usernamechange 0 rules_infb 1 rules_cid 14 help_infb 1 help_cid 15 showspoilertag 0 showvideotag 1 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 0 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 3 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 3 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 0 maxpersotext 50 ordering_system replyid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 60 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access auto integration_login communitybuilder integration_avatar communitybuilder integration_profile communitybuilder integration_private auto integration_activity auto boxghostmessage 0 userdeletetmessage 1 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 1 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 3 mod_see_deleted 1 bbcode_img_secure text listcat_show_moderators 0 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 1 userlist_count_users 1 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 0 thankyou_max 10
Third-party components: CommunityBuilder 1.7
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Discuss 1.6.4
Modules: Kunena Latest 1.6.4 | Kunena Stats 1.6.4
When you have properly set up the Kunena menu properly it will work regardless of how you access your forum.
I can also see that you have multi-language environment in your site? Kunena 1.6 is lacking support for Joomla multi-language menus (it was added into k1.7.0).
- kunenamies
Cannot wait for Kunena 1.7 and the new Kunena Discuss and proper language support.
Btw, is it OK to change the Kunena menu label names without affecting Kunena functionality?
And I am very grateful for the support!
The multi-language support in K1.7 for Kunena works by adding all languages into the same Kunena Menu. Just don't use All after you add the language support as it probably messes things up.
I've been able to successfully enable to the Kunena menu on frontend but when I try to select a single category or a topic, the menu completely disappears. What might be causing this?
Warning: Using direct link to Kunena component. No suitable menu item found.
Is there a way to create a menu item for this, I'm not seeing one?
Thanks,
Eric
