Kunena 7.0.8 Released
Sticky [Merged topic] How do I restore my Kunena menu?
16 years 2 weeks ago - 16 years 2 weeks ago #54491 by PaRaDiSiAk
Excuse me for my poor english (i'm french)
I installed Kunena 1.6 beta 1 over 1.5.20 and everything went fine except the Kunena horizontal menu in the top of the forum : it doesn't appears.
In backend in Kunena control panel I clicked "Create menu" and I got an error (sorry, in french...) :
- Kunena Erreur interne: Veuillez activer le mode debug et signalez ce problème dans le forum Kunena www.kunena.com . (my translation : Kunena internal error : please activate debug mode...)
Followed by :
- Le menu de navigation Kunena et le lien principal forum ont été créés (my translation : Kunena navigation menu and main link have been created)
After these messages, nothing appears. No menu !
Do you have an idea ? :huh:
Legacy mode: Enabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled | htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 64M | Max file upload: 10M
Kunena version detailled: Installed version: 1.6.0-BETA1 | Build: 3068 | Version name: | Kunena detailled configuration:
Last edit: 16 years 2 weeks ago by PaRaDiSiAk.
The topic has been locked.
16 years 2 weeks ago - 16 years 2 weeks ago #54492 by iLucato
Have you checked from Joomla Menu if Kunena Menu was created?
Joomla > Menus > Kunena Menu
Click on Kunena Menu and check if the sub-menus are created and published. ;0)
Last edit: 16 years 2 weeks ago by iLucato.
16 years 2 weeks ago #54496 by sozzled
This is a real problem! I had to go through the menu re-creation procedure again, myself, only a couple of hours ago.
See Links don't work for another user's experience.
I found that I had to go through the menu creation procedure twice! That is, trash and delete Kunena menus, create menu, then trash and delete them again and create menu again. Takes a few minutes and it's a pain in the neck ... perseverance and patience. Will eventually be fixed.
Thanks for reporting the issue.
16 years 2 weeks ago - 16 years 2 weeks ago #54497 by PaRaDiSiAk
I have checked : I have N-O-T-H-I-N-G !
Kunena Menu has not been created in Joomla > Menus > Kunena Menu
Edit : Thank you too, sozzled for your answer, I'm reading the topic...
16 years 2 weeks ago #54506 by sozzled
Legacy mode?! Why are you running legacy mode? Does legacy mode interfere with the Mootools Upgrade plugin? :unsure:
16 years 2 weeks ago #54508 by PaRaDiSiAk
I'm in legacy mode, yes, because i need the legacy mode for a component.
Do you think legacy mode can interfere with something ?
What is the Mootools upgrade plugin ?
Time to create page: 0.310 seconds
