Question My Forum is having problems loading
Sometimes people write here "I read somewhere ..." and that's all we hear. I'm not doubting that you read something but, in response, I must ask you, "Where did you read this?" :dry: Yes, K 1.6.1 fixed many problems with K 1.6.1. You are already using K 1.6.1.jonny3010 wrote: ill give it a go but i read somewhere that a guy have the same problem so he when to 1.6.0 from 1.6.1. and it worked again so im thinking kuneuna team has change somthing?? to do with SEO
can you give me a link for K 1.6.0 maybe or tell me when new K comes out
Well, I'm sorry but that doesn't help us very much, does it?[I read a topic] on this forum ... went to look for K 1.6.0 and could not find [it] and I closed all the tabs a and lost the topic
jonny3010 wrote:
I'm sorry, I don't understand your question. In msg #3 of this topic you show (in your configuration report) that you are using K 1.6.1. Why are you referring to K 1.6.0? What "new" version of Kunena are you expecting to "come out". What do you expect this "new" version to do for you?Can you give me a link for K 1.6.0 maybe or tell me when new K comes out
if you can give me a link to 1.6.0 i would be happy
You can obtain any publicly-released version of Kunena 1.6 here: joomlacode.org/gf/project/kunena/frs/?ac...&frs_package_id=5247 .
As you we have seen, in relation to the original "redirect loop" problem,
jonny3010 wrote:
[strike]... and I guess that's where we should leave this discussion.[/strike] But not working the way that it should be working.thanks its working now ...
I don't know what you expect will happen with K 1.6.2 or what SEO settings you specifically want to use that are different from the standard Joomla SEO settings ... or maybe I have misunderstood what you mean by the term settings.jonny3010 wrote: ok i think ill stick with 1.6.1 and wait for 1.6.2 and then see if the SEO settings that i want will work
The Kunena project team welcomes the feedback from users to help improve the product. If you have ideas for improving Kunena in the future, please let us know by contributing to one of the topics in Feature Requests category.
The problem is not knowing how to setup Joomla SEO. The solution is applying the guide given in Search Engine Optimization (SEO) . The key to the success is the presence of a well-tempered .htaccess file. I believe this is the cause of the problem. The solution has been given in another topic. I believe the solution is to replace the user's .htaccess file with the standard one that comes with the Joomla installation kit (which is included as htaccess.txt - you need to rename it to .htaccess). Fix that up, reapply the standard Joomla SEO settings and everything should work. It's all explained in the Wiki article.
i was thinking do i have to do any thing to do with seo in the kunena settings
