- Thank you received: 3
Kunena 6.4.8 Released
Question Remove Kunena Login and Registration?
- ComposerRyan
- Junior Member
- haightdays
Also, even though I've set registered users to no, the forum categories won't show up until I've logged in. Cheers, Bruce.
Our recommendation: upgrade to K 1.6.3 and then you can use the techniques discussed in this topic.
- haightdays
The information in this topic relates to K 1.6. I had hoped that I had explained that the technique used in K 1.6, to make a small changed to a configuration settings, would not work for you with K 1.5.11.haightdays wrote: Thanks for a speedy response but I don't want support, I want to remove the login function without spending half the day finding out what Mootools is and why 1.6 would load onto my site.
There is a way you can changed things in K 1.5.11 - and you may be able to find how to do that if you search the K 1.5 Template and Design category (perhaps) - but I would be irresponsible if I did not point out that the version you are using is no longer considered endorsed, reliable or supported by this community. In other words, if you find a way to achieve your goal, you're "on your own".
- haightdays
I had a mooch around in the forum and found someone had simply removed the code controlling the links so that it still says you need to register and/or login but without the live links. Sorted.
Cheers.
