- Thank you received: 566
Kunena 6.2.6 released
Question size72 avatars does not exist while size200 avatar does
1) are all the avatars working in Kunena? If not, where?
2) are you trying to display avatars somewhere else?
The following image shows the standard folders that should be installed with K 1.7 in your ../media folder:
But before that you should check Kunena version:
docs.kunena.org/index.php/Detecting_Kunena_Version
That should create the avatar image of size 72 (you can have whatever size you want to).
I'm not sure why avatars are not generated inside Kunena -- do you have modified version of our template?
Matias wrote: You should use this instead:
Code:$avatarURL = KunenaFactory::getUser()->getAvatarURL(72);
the only modification I did to Kunena:
/components/com_kunena/template/default/loginbox/login.php
removed lines 34 to 75 and replaced it with a login from JFBConnect
in administrator/components/com_kunena/kunena.xml
I know I started with a 1.7.2 installation.
Where would I use?
thank you so much for the help!
PS. In Kunena 2.0 you can write a simple plugin which does the same as you're trying to do.
Also, all size36 avatars within the userlist are always displayed correctly.
Can you provide the code you changed? (use code tag)
removed and replaced with a JFBConnect login easy-tag
