Question Templates for Kunena 1.7 ?
- snilloconator
- Premium Member
- aka snilly
Also can you add the template zip file here. I'll take a look.
When I click that little arrow to collapse one category section, nothing happens?
I havent used K1.6 before so I couldnt test the templates with that version.
- snilloconator
- Premium Member
- aka snilly
- Nihil
- Visitor
Read this Kunena Mootools Thread
Mootools conflicts!! I HATE MOOTOOLS!!!
Can-you check the template package if the xml file is in there ?
- Nihil
- Visitor
Here is the link i used. Here is the link i used.
This is the exact error:
JInstaller: :Install: Cannot find Joomla XML setup file
Aphotic (1) works fine aside from it not showing the kunena tabs.
