- Thank you received: 566
Question Category Icons Keep Disappearing
12 years 5 months ago #21
by Matias
Replied by Matias on topic Re: Category Icons Keep Disappearing
Yes, something is really corrupting css files. Are the original files corrupted?
Ass css files are static, there are only few possibilities of what can be happening.
1) Joomla plugin corrupts the files
2) Apache plugin does something for those files
3) Caching does it
4) Something else does it
I know that it isn't Kunena..
3) Caching does it
- AndyInSpain
- Topic Author
- Senior Member
- Thank you received: 2
12 years 5 months ago - 12 years 5 months ago #22
by AndyInSpain
Replied by AndyInSpain on topic Re: Category Icons Keep Disappearing
Hi Matias, hope you are well.
Well,I was almost convinced that the CSS was becoming corrupted during the minifying process. I say this because I reset our forums' configuration, which restored the icons, and all was fine for two weeks. Then I made some changes to the CSS, minified it and the next day the icons disappeared again. I don't pretend to understand why, nor why there is a delay. And in any event, Ruth had not made any changes to the CSS but still had the problem, so now I am not so eager to blame the minifying process.
Now I have reset the forums configuration again, but the icons have not reappeared this time. My next step will be to uninstall and reinstall Kunena. This is a real pain but it's the only solution I have. And as we don't know for sure what is corrupting the CSS, there is no guarantee it won't happen again.
Last edit: 12 years 5 months ago by AndyInSpain.
- KiberLovag
12 years 5 months ago #23
by KiberLovag
KiberLovag
Ócsa, Hungary
Replied by KiberLovag on topic Re: Category Icons Keep Disappearing
Just give it a try, close every css, rename the folder containing the original css (just for backup), and upload the factory-default css just see, if you can see icons or not... if yes, than search for " in the saved ones... maybee the same problem, but the interesting thing that you can get to this error by several ways... :whistle:
KiberLovag
Ócsa, Hungary
12 years 5 months ago #24
by Matias
It's a good idea to make a copy of the template. Kunena 1.7 doesn't itself touch the files and I really don't see any reason why anything else would like to do that, too.
BTW Kunena 2.0 will have its own CSS minifier and compiler that creates new files from the original ones (after every update on either CSS or template settings).
12 years 3 weeks ago #25
by MoJo_Fear
Replied by MoJo_Fear on topic Re: Category Icons Keep Disappearing
If anyone is struggling with this listed to ruth! She is right! But I just reinstalled and did my change from the backend = it will not change the values to 555 it keeps them at 644!
Time to create page: 0.393 seconds
