Question [Merged topic] XAMPP-related "Strict Standards" errors
15 years 5 months ago #96588 by StNick0912
For example :
Strict Standards: Only variables should be assigned by reference in C:\xampp\htdocs\math\administrator\components\com_kunena\admin.kunena.php on line 32
Strict Standards: Non-static method CKunenaConfig::getInstance() should not be called statically in C:\xampp\htdocs\math\administrator\components\com_kunena\libraries\factory.php on line 28
Strict Standards: Only variables should be assigned by reference in C:\xampp\htdocs\math\components\com_kunena\class.kunena.php on line 28
Strict Standards: Only variables should be assigned by reference in C:\xampp\htdocs\math\components\com_kunena\class.kunena.php on line 29
Strict Standards: Only variables should be assigned by reference in C:\xampp\htdocs\math\components\com_kunena\class.kunena.php on line 31
Strict Standards: Only variables should be assigned by reference in C:\xampp\htdocs\math\components\com_kunena\class.kunena.php on line 32
Strict Standards: Non-static method KunenaError::checkDatabaseError() should not be called statically in C:\xampp\htdocs\math\components\com_kunena\class.kunena.php on line 54
Strict Standards: Non-static method html_Kunena::showFbHeader() should not be called statically in C:\xampp\htdocs\math\administrator\components\com_kunena\admin.kunena.php on line 90
That is about 1/5 of what I'm seeing, and it is everywhere there is a call to the forum, even in the admin menus for the forum. As you can see I am running from xampp on a local machine.
Any help would be appreciated. Thank you in advance.
15 years 5 months ago #96589 by nima.abbc
did you check your joomla or kunena version?
because i just installed installed joomla 1.6 and kunena 1.6.4 and there was no error!
15 years 5 months ago #96590 by nima.abbc
i just did some search:
its a common issue in joomla 1.6 and there is a topic in joomla forum to solve it:
forum.joomla.org/viewtopic.php?p=2493923
of course i didnt try it since i didnt have same problem!!
15 years 5 months ago #96591 by xillibit
What Kunena version are-you using ?
k1.6 works well under php 5.3+
15 years 5 months ago #97912 by Matias
Yes, most of the code was written by using PHP <5.3, which still allowed static calls without marking functions as static and so on. We are slowly (in 2.0) getting rid of these notices, but there's no plan to fix all of them until Joomla changes it's API to work in the strict mode.
BTW: those are actually not errors of any kind, they are just a bad way to write code in PHP 5.3 (legacy from PHP4).
14 years 7 months ago #121714 by Alemantico
Hi, dear KUNENA - supporters. Just today I tried to install your newest KUNENA - Release (1.7.2). I'm running joomla! Ver 2.5.3 on my localhost (xampp. Just started using Joomla! 3 days ago.)When installing your newest version, I instantly received the following error message below (I added the complete config - setting error message as an attachment):
Strict Standards: Declaration of KunenaControllerInstall::display() should be compatible with that of JController::display() in C:\xampp\htdocs\Joomla! 2.5\administrator\components\com_kunena\install\controller.php on line 22
Strict Standards: Declaration of KunenaModelInstall::getError() should be compatible with that of JObject::getError() in C:\xampp\htdocs\Joomla! 2.5\administrator\components\com_kunena\install\model.php on line 1797
Strict Standards: Only variables should be passed by reference in C:\xampp\htdocs\Joomla! 2.5\administrator\components\com_kunena\install\view.php on line 43
Strict Standards: Only variables should be passed by reference in C:\xampp\htdocs\Joomla! 2.5\administrator\components\com_kunena\install\view.php on line 45
Strict Standards: Only variables should be passed by reference in C:\xampp\htdocs\Joomla! 2.5\administrator\components\com_kunena\install\view.php on line 46
Strict Standards: Only variables should be passed by reference in C:\xampp\htdocs\Joomla! 2.5\administrator\components\com_kunena\install\view.php on line 49
Strict Standards: Only variables should be passed by reference in C:\xampp\htdocs\Joomla! 2.5\administrator\components\com_kunena\install\view.php on line 54
Time to create page: 0.146 seconds
