Important [Resolved - user abandoned Kunena] General advice about Joomla, Kunena and website design
i appreciate that this is open source, and thanks to the creators i understand there's alot of time put in this, and keep up the good work.
however, its too much frustration for no reason while till now i could've just installed phpbb, thanks again and i wish you the best.
Now I understand. Yes, Kunena needs Joomla to work! Therefore you have to create the Joomla website and then you install the Joomla extension called Kunena.kici wrote: as i'm used to there being a website, and a forum,
and what i have is a forum inside the website
This problem you are having is not really a Kunena problem, it's a website design issue that involves a bit of understanding about how Joomla works. You will probably get a lot more useful help by looking at the Joomla support forum ( forum.joomla.org ) but in very basic terms, what you probably want to do is to have a site template that (may be different from your "normal" site template) that only displays the Kunena component. You can also get some help by looking at a few good books written about Joomla.
If you don't want to spend too much time worrying about these website design issues, you might consider paying a specialist to do them for you.
as i stated its fine no worries, just for future users it will be helpfull if they dont have to go thru the same, a forum is supposed to be a forum, not a forum inside a website, already found how to link users with phpbb so anyways good luck
I saw your modules are applied to the forum page too, that easy.. do not include your module in forum page. (that must be in module position --> there menu to access it, dont chose link to forum menu.
Love Simplicty
read...... and learn........
My Joomla Test Site
kici wrote: nah thanks for all the help, but a forum isn't supposed to be half a page withing a website, it isn't any web template that's causing it i tried the original ones also.
If you would read the very basics of Joomla you would have found out that you can make Kunena your homepage and remove all other modules and menus showing. However you need to invest into learning how to do the very basic configuration of Joomla. These changes take less than 5 mins. If that is too much to ask, you might be better off not using Joomla and Kunena.
Hope this helps!
