rimple wrote:Can you [advise] what other [forum] component I can use with Kunena, so that I can have ... [two menu items] i.e. [one that links to an] "Announcements" [category] ... and [the other that links to the broader] "Message Board"
I have rephrased your question a little differently. Basically, your questions are totally concerned with how you would like to set up your Joomla
menu.
Part of our problem is understanding why you (or anyone) would want
two, totally separate, forums running on the one website. So, let's look at the reason you might possibly want to do this.
If your "Announcements" area (births, deaths, marriages, classified advertisements, etc.) is only for placing notices by
you then there are
other alternatives to using a forum. But, even if this "announcements" area is merely for posting notices and not (as I suspect) for discussions, there are still other ways of doing this that don't involve
Kunena. There are other components in the
Joomla Extension Directory
that handle "listings".
But, even if you want your users to post their own "announcements" topics and you also want broader discussions to take place, there's another way to help your users find where they can do these things. When you get right down to it, that's all that a menu does: helps your users find where they can get in touch with the services that your site provides for them.
So, let's look at your requirement in a slightly different way. You want to show your users that they can post "announcements" and you also want to show that your site also has a general "message board". One, very easy and highly effective way you can do this is to use
Kunena, as you have already set it up right now, with one
section for "announcements" and another
section (or sections) relating to other matters ... but, if you asked me to implement the solution, I would definitely not create two, discrete and separate, menu items. I would create, instead,
one menu item and I would label it "Announcements and Message Board".
I would make one menu item "Announcements and Message Board" and I would link it to my
Kunena forum. When my users arrived at my
Kunena forum they would see the different
sections (one for "announcements" and the other(s) for more general messages) and use them accordingly. If my users had trouble deciding where to post their messages, I would provide them with other help. I would write descriptions in the categories or create "sticky" posts, just like we do here at Kunena.com.
It's really not such a big deal:
Kunena can do everything you want. Perhaps, if you look at what you're trying to achieve in a different way, you will see that there
are other, simple and non-technical solutions that are just as effective as the one that you're trying to implement. I hope that my suggestion solves your problem. I really don't think the solution lies in worrying about how to create
two separate Joomla menu items or worrying how to resolve the hyperlinks.
