Kunena 6.4.9 & Kunena 7.0.1 Released
The Kunena team has announce the arrival of Kunena 6.4.9 [K 6.4.9] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
The Kunena team has announce the arrival of Kunena 7.0.1 [K 7.0.1] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Sticky How to protect my forum from spam
15 years 7 months ago #50546 by cally6008
I use ChronoForms as the registration page for my website and have had very few, if any, spammers registering.
15 years 7 months ago #50556 by xillibit
a captcha system is a good thing to prevent spams, do you using one ?
15 years 7 months ago #50558 by cally6008
Sorry, was this aimed at me ? Yes, the ChronoForms that I use has an inbuilt captcha and also an option (like registering on here ?) to ask a question and receive the correct answer before allowing registration to take place
15 years 6 months ago #53505 by ranjeet
cfBlockCountry (Plugin)is really nice solution to block any country to access without using ip address.one of my friend asked me to use this.For example if you want to block access of the site from any IP in United States you can use this plugin. I have used this to prevent unwanted access to my website and you can also use this if going through the same problem . you will definitely feel better after using this. you can download it from the given link below:-http://www.codefire.in/open-source.html
15 years 6 months ago #54302 by xreliable
In my experience of running forums since the days when Compuserve ruled the Internet, is that captcha systems only work to **% (YMMV) efficiency i.e. they can and are beaten regularly if you have a busy forum/site. I've had better luck manually configuring Q&A or a combination.
There are several popular blacklist services with APIs and online lookup such as:
www.spamhaus.org/
www.spamcop.net/bl.shtml
I've found this site pretty useful for quick manual reference but they also have an API:
www.stopforumspam.com/downloads/
What I'm wondering is if there is anything planned for a Kunena plugin for this or similar services?
15 years 5 months ago #57695 by JoS
I'm very new to the world of web building and Kunena so please go easy on me!!
I've discovered and removed some spam from my forum and have deleted them as they appeared but now the ability to delete registered users has GONE!
I've had 3 appear in the last 24hrs even with CAPTCHA switched on.
One of them is not listed in my User Profile Manager and i'm concerned this one may have done something to alter my ability to delete users - is this possible??
How do i stop them please? I'm using Joomla 1.5 & have searched through the extension directory but am not sure which one is right for what i need - any suggestions here?
Thanks in advance for your help
Jo
Time to create page: 0.326 seconds
