- Forum
- Community self help
- Kunena and other Joomla extensions
- Miscellaneous, off-topic and general Joomla
- How to protect my forum from spam
Kunena 6.0.8 Released (17 Jan 2023)
The Kunena team has announce the arrival of Kunena 6.0.8 [K 6.0.8] which is now available for download as a native Joomla extension for J! 4.2.x. This version addresses most of the issues that were discovered in K 6.0 and issues discovered during the development stages of K 6.0.
Merged How to protect my forum from spam
- CheechDogg
- Premium Member
Using this method allows you to block not only a single IP address but also a full range which is what spammers do, they stay within a certain range, when they try to access a site and see that their IP has been banned they try a 2nd one, most of the times those IPs are in the range and therefore they either say "screw this" and not try again or if they really want to spam your forums they may use "proxy servers".
I recommend you use the .htaccess method, this is very easy to use and set up if you have cPanel access to your server. If you don't just go to your sites root directory and find the .htaccess file.
- CheechDogg
- Premium Member
With proper research on the internet and with some good reading patience this can be done.
MonkeyDragon I understand this can be quite confusing and pretty darn frustrating especially after being ripped off "The last option then opens up a whole can or wroms though as I am trying to keep expenditure to a minimum having been ripped off to the tune of a few thousand pounds by a rather scrupilous company who I commissoned to originally build the site" this alone would of really got me heated.
But if you want I can help you out with this. Let me know if you would like me to help you out and I will give you more information as to how we can make this happen.
- MonkeyDragon
CheechDogg wrote: But if you want I can help you out with this. Let me know if you would like me to help you out and I will give you more information as to how we can make this happen.
Thanks for the offer, I shall take you up on that.....it'll be like 'Cheech and Chong Do Spammers'!
Unfortunately, I'm away for a few days on business so unable to do anything at the moment. I do have Cpanel access to my server, although quite what to do once there I don't know. My intial consultation with Mr Google about htaccess merely served to leave me a tad confused.
I may switch to a newer version of Kunena too, having seen CheechDogs site I was mightily impressed.
Thanks for your help all.......I'm sure you;ll hear much more from me!
- CheechDogg
- Premium Member
- Charl Laas
- Junior Member
I have the same problem with spammers and have some other small issues. One of my categories are open to the public (non registered users). I have enabled the build in Kunena Captcha (and tested it, seems to be working fine). Unfortunately I'm still getting 4-5 spams per day from multiple IP addresses.
The Category: General Discussions (www.orthokinstitute.com/forum/4-general-discussions) is set up in the back end to be moderated and approved before showing the posts, which is working fine. However before I can approve/delete the spam posts it is already showing 'live' in JomSocial activity stream and in the recent topics module. (All these components are running the latest release versions).
It would also be nice if the super administrator can have an option to do multiple topic deletes instead of having to access each topic individually deleting it and then having to re-access it again to permanently delete the topic. It is a bit time consuming if you have to do 10 spams a day.
Experience is that marvelous thing that enables you to recognize a mistake when you make it again.
Franklin P. Jones
We understand the need that some people have for these open categories. It's a pity that spam merchants abuse this kind of generosity. Having said that, if you don't restrict your forums (by requiring people to register and login before they post) you're facing an uphill battle trying to keep out spam.
You can delete multiple topics from the Index view. Check the topics (the checkbox on the right) then choose delete from the drop-down near the bottom of the page.
- Groenteman
- Junior Member
- Thank you received: 2
In simpleboard I used this php code to block guests to post "href" It worked
very well to prevent guest to spam links.
<?php
$parent=(int)$parentid;
if ($my->id==0) {
$pos=strpos(strtolower($message),"href=");
if($pos>-1){
$checkSecurity = false;
else{
$checkSecurity = true;
if (empty($sb_authorname))
echo _POST_FORGOT_NAME;
else if (empty($subject))
echo _POST_FORGOT_SUBJECT;
else if (empty($message))
echo _POST_FORGOT_MESSAGE;
else if ($my->id==0 && $checkSecurity==false)
echo "Spam check failed! - guest are not allowed to post links"; // replace this with whatever text you would like your user to see.
else {
if ($parent == 0)
$thread = $parent = 0;
Could this code be added to kunena post.php?
Please help me out,
Groenteman
- Charl Laas
- Junior Member
I do have the following concerns
1. Up to K 1.7.1 I never had these spammers. Upgrading to K1.7.2 and higher using Kunena's build in Recaptcha the spamming started. I confirmed this by upgrading my sites 1 month apart. Every time I Upgraded to 1.7.2 the spamming started.
2. An unapproved post still appears in JomSocial activity stream and in the Kunena Latest topic module. To me this is a bug.
Franklin P. Jones
Please don't complicate this topic by reporting what you see as a JomSocial/Kunena Latest software defect in this topic. That issue belongs in a separate topic and, yes, it may be a bug.
Forum Access
- Not Allowed: to create new topic.
- Not Allowed: to reply.
- Not Allowed: to edit your message.
- Forum
