- Forum
- Community self help
- Kunena and other Joomla extensions
- Miscellaneous, off-topic and general Joomla
- How to implement Search Engine Optimisation - SEO - in Joomla
Kunena 5.2.2 released (13 Jan 2021)
The Kunena team has announce the arrival of Kunena 5.2.2 [K 5.2.2] which is now available for download as a native Joomla extension for J! 3.9.x. This version addresses most of the issues that were discovered in K 5.2 and issues discovered during the development stages of K 5.2.2
Merged How to implement Search Engine Optimisation - SEO - in Joomla
One of the most difficult parts of Joomla is the Joomla menu system. We recommend that you read Customised menus in the Wiki.
However the problem that you're having does not really have a lot to do with the menu alias name. The problem that you're having has to do with how you setup Joomla Search Engine Optimisation (SEO) . For that reason, I have merged your topic with one that addresses those issues. Please read the article in the Wiki and setup SEO in the way that we've recommended and you will not have those horrible looking SEF URLs.
From that, I resulted in getting a menu item alias of: 2012-04-25-14-24-24
My question is whether I should retain this or should I just change it to "forum" for better SEF or does it even matter?
; Kunena menu items
COM_KUNENA_MENU_FORUM="Forum"
COM_KUNENA_MENU_HELP="Help"
COM_KUNENA_MENU_RECENT="Recent Topics"
COM_KUNENA_MENU_INDEX="Index"
COM_KUNENA_MENU_MYLATEST="My Topics"
COM_KUNENA_MENU_NEWTOPIC="New Topic"
COM_KUNENA_MENU_NOREPLIES="No Replies"
COM_KUNENA_MENU_PROFILE="Profile"
COM_KUNENA_MENU_RULES="Rules"
COM_KUNENA_MENU_SEARCH="Search"
; Menu aliases (all lowercase, only a-z, 0-9)
COM_KUNENA_MENU_FORUM_ALIAS="forum"
COM_KUNENA_MENU_HELP_ALIAS="help"
COM_KUNENA_MENU_RECENT_ALIAS="recent"
COM_KUNENA_MENU_INDEX_ALIAS="index"
COM_KUNENA_MENU_MYLATEST_ALIAS="mylatest"
COM_KUNENA_MENU_NEWTOPIC_ALIAS="newtopic"
COM_KUNENA_MENU_NOREPLIES_ALIAS="noreplies"
COM_KUNENA_MENU_PROFILE_ALIAS="profile"
COM_KUNENA_MENU_RULES_ALIAS="rules"
COM_KUNENA_MENU_SEARCH_ALIAS="search"
The best advice I can give is summed-up oral tradition given in the nursery rhyme Little Bo Peep : "leave them alone and they will come home wagging the tails behind them." If it works, leave it alone. If it doesn't then you need to change something.
I have a J! 2.5.4 website that has the kind of menu item alias like you've got - yyyy-mm-dd hh-mm-ss - and it works for me. I get perfectly-formed SEF URLs as a result and I can navigate around my Kunena forum without doing anything "special". I don't pretend to understand how the Joomla router handles these things but it seems to cope quite well.
- thelastrich
I was upgrading my joomla from 1.5 to 2.5 using JUpgrade.
Everything was fine, but i got a problem, the SEF url doesn't work with kunena.
It works with articles, categories... But not with kunena.
I have .httaccess activated and working
The first issue is in the link alias when I use kunena menu, it has a
/jupgrade/Read%20Private%20Message/forum.html
Instead of what should be
/jupgrade/forum.html
Whenever i reach that link (one or the other) i get a 404 not found.
Another thing is that when i reach some forum category (first going with SEF off, then activate it) like for example:
/jupgrade/Read%20Private%20Message/forum/2-welcome-mat.html
It recognices that URL like the article with id=2
It was all working fine until I upgraded to 2.5
Do you have any idea of what is happening??
Thank you in advance.
- thelastrich
Thank you for your answer, but still that doesn't fix my problem.
As I said I had it working before, and I have it working now (in the joomla 1.5) but in the updated one (joomla 2.5) I cant make it work.
I renamed htaccess.txt to .htaccess
I use the config that says there
Have the kunena menu published
If I create a new menu item, linked to kunena index, it works one click, then when im on the index if i click any category, or the same link again, it throws me a 404 again and the url contains the "read private message" before the "forum" string.
Using the default kunena menu it never works.
I dont understand why that "read private message" string on the URL.
Any ideas?
- thelastrich
Thanks to this answer:
www.kunena.org/forum/154-Miscellaneous-o...omla?start=10#110182
As it says here:
docs.kunena.org/index.php/*_Commonly-ask...re_my_Kunena_menu.3F
in: How do I restore my Kunena menu?
I deleted the old menu, created a new one, and everything works fine.
Thank you!!
I am currently building my website, until a few days ago I used WampServer to build it localy, a few days ago I moved my website to a live server, ever since that move when SEO urls are active in the kunena settings I can't enter any of the categories in the forum, some shows the correct SEO URL but when clicked the URL at the address bar changes correctly but the index refreshes.
Other categories get a very long, very strange URL and when click gives me the following error:
Bad Request - Invalid URL
HTTP Error 400. The request URL is invalid.
The URL for the problematic forum is www.sr-computers.co.il/forum
The website and forum are in Hebrew.
I believe the installed version is 1.7.0 but am not quite sure.
if it helps, when I was using WampServer I was using apache server and now on the live server it is IIS7 on a microsoft windows 2008 server.
PHP version 5.x, not sure which exactly, mysql version 5.x as well.
That's all the information I can think of, please help with the issue.
Thank you.
This message contains confidential informationhtaccess: Missing | PHP environment: Max execution time: 600 seconds | Max execution memory: 32M | Max file upload: 20M
Joomla default template details : effectivesolutions | author: TG | version: 1.6.0 | creationdate: 03-02-2011
board_title SR מחשבים board_offline 0 board_ofset 0.00 offline_message <h2>פורום הSR מחשבים נמצא כעט בתחזוקה.</h2>
<div>נסה שוב מאוחר יותר!</div>enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template default showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 1800 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 0 pubwrite 0 floodprotection 30 mailmod 0 mailadmin 1 captcha 1 mailfull 0 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 1024 allowfileupload 0 allowfileregupload 1 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 2048 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 9 help_infb 1 help_cid 11 showspoilertag 1 showvideotag 1 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 0 ebaylanguagecode he-IL fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 1 sefutf8 1 showimgforguest 1 showfileforguest 0 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 150 ordering_system replyid post_dateformat datetime_today post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access auto integration_login communitybuilder integration_avatar communitybuilder integration_profile communitybuilder integration_private uddeim integration_activity communitybuilder boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 1 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 168 show_session_type 0 show_session_starttime 0 userlist_allowed 0 userlist_count_users 1 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 1 thankyou_max 10 email_recipient_count 0 email_recipient_privacy bcc email_visible_address This email address is being protected from spambots. You need JavaScript enabled to view it. captcha_post_limit 0 recaptcha_publickey 6Lcpm9ESAAAAAC0FkX_jFHvD6rjhrmkLn7Oh2N9I recaptcha_privatekey 6Lcpm9ESAAAAAPvrhuH_3NADtDH3GXzigEUwjwl3 recaptcha_theme clean
Third-party components: CommunityBuilder 1.8.1 | UddeIm 2.8
Forum Access
- Not Allowed: to create new topic.
- Not Allowed: to reply.
- Not Allowed: to edit your message.
- Forum
