Question Avatar upload doesn't work
I can't be sure of anything in this regard. The only suggestion I have to offer is to check and double-check each and every directory, sub-directory and file in you Joomla website. Perhaps you thought you'd changed them all, but maybe the changes weren't propagated recursively throughout the whole sub-directory structure?Am I missing a permission setting in another directory that is important?
Your version of PHP, if it's less than 5.2.1, does not support the function "sys_get_temp_dir".
What you can do as a fix if you don't want to compile 5.2.1 or higher and re-install, is you can put the following in about line 27 on the file
/components/com_kunena/template/default/plugin/myprofile/myprofile_avatar_upload.php
right after...
"require_once(KUNENA_PATH_LIB .DS. 'kunena.file.class.php');"
if ( !function_exists('sys_get_temp_dir')) {
function sys_get_temp_dir() {
if (!empty($_ENV)) { return realpath($_ENV); }
if (!empty($_ENV)) { return realpath( $_ENV); }
$tempfile=tempnam(uniqid(rand(),TRUE),'');
if (file_exists($tempfile)) {
unlink($tempfile);
return realpath(dirname($tempfile));
That will fix the problem in the mean time.
Cheers m8,
Jimmy
* JFile::copy: Cannot find or read file: '/tmp/kn_foUYtS'
* JFile::copy: Cannot find or read file: '/tmp/kn_q4QDro'
* JFile::copy: Cannot find or read file: '/tmp/kn_zvyouU'
Help -> System Info -> Directory Permissions tab
Check that they are all writeable.
@ merola:
Can you send information from your system: Operating system, Joomla FTP user, Apache user.
What are the permissions of those files? Owner, group, mode (0600?) ?
- lakehousetech
Or just upgrade to K1.5.4
I just got back and upgraded to 1.5.4 (released while I was away on vacation) which has solved the upload problem :woohoo:. I haven't encountered any more bugs yet, but I'll continue to test it out over the next week. Thanks again to everyone!
Chri
For Kunena 1.5.4
Edit kunena.file.class.php (/components/com_kunena/lib/)
and replace the old code with new code:
old:
new:
Or use the attached file for Kunena 1.5.4 kunena.file.class.php and override the existing file in components/com_kunena/lib/
