- Thank you received: 1
Question [Solved] Login alteration problem
Attachment profilebox-20090617-3.zip not found
in www.betorama.net/modules/mod_yoo_login/mod_yoo_login.css.php
span.yoo-login, span.yoo-login span {
display:block;
float:right;
position:relative;
top:-2px;
And in www.betorama.net/components/com_kunena/t...5.3/kunena.forum.css
#Kunena td.fb_profileboxcnt {
text-align:left !important;
width:60%;
Please test the following css changes (red marked):
display:block;
float:right;
position:relative;
top:-2px;
There is no such code in mod_yoo_login.css.php
I made the change in kunena.forum.css , it is still the same:
www.betorama.net/index.php/forum.html
Could you explain precisely how you want the login to look? Maybe do a mock-up picture. I still a little unsure and don't want to keep you going around in circles
Regards.
I don't want kunena's login and i want it like in the photo i am showing you!
Show Latest Posts | My Profile | Logout | Announcements | Advanced Search
text when user logs-in?
- You'll need to create a new module position in the profilebox.php [YOURSITEURL/components/com_kunena/template/default/plugin/profileboxprofilebox.php]. More information on this in
Kunena Documentation
and here on the
Kunena.com Forum
This is relevant to this example (please change kunena_profileboxleft to whatever you want)
<div class = "fb_profilebox_modul">
<?php
$document = &JFactory::getDocument();
$renderer = $document->loadRenderer('modules');
$options = array('style' => 'xhtml');
$position = 'kunena_profileboxleft';
echo $renderer->render($position, $options, null);
</div> - Edit the kunena.forum.css #Kunena tr.fb_sectiontableentry1 td.td-1 {kunena.forum.css (line 65)
background:#EBEBEB none repeat scroll 0 0;
border-left:0 solid #E3E4E3;
color:#999999;
text-align:left;
.... to align the "Welcome Guest" to the left - Finally you will have to asign the yoo_login module to position "kunena_profileboxleft" in the Joomla! module manager
I've attached the altered profilebox.php (it has been tested and works)
Attachment profilebox-20090618.zip not found
Thanks a lot!!!
