Question Problems with Siteground template
I'm having a problem with my template from siteground, because it's not displaying the kunena forum with the whole width. It's too short, like if it were columns on the side.
I've already disabled the left and right columns, but it's the same. For what I've read, the problem is my joomla template that only works with two or three columns...
Can anyone help me?
My site is here .
The bottom line is that Siteground templates look good but they're a lot more complicated to fix that other templates. Only recently I tried to help a user with a Siteground template-related problem (see Kunena forum width not full ) but he discovered that he could not use the fix for other reasons.
After considering the weight of evidence against Siteground , I am inclined to now think that fixing these problems takes more effort that it's worth and it's probably better to use another Joomla template provider.
to
I installed my new template and assigned it only to the Kunena menu item.
As long as you have nothing published in the Left or Right positions on that page, it seems to work fine.
This may not be the best solution to the problem, but it is working for me, so I thought I would pass it along. Other SiteGround templates might be able to be edited in a similar manner.
Kunena 4.0.11, Joomla 3.5.1, CB 2.0.14, DOCman 2.1.5, uddeIM 3.8
I'm using a SiteGround template and really didn't want to change it, as it is a good design for my needs. I've already tweaked it quite a bit, but didn't realize this problem until I installed Kunena on the site today. I figured out a way around it. I created a copy of the template ("Relax1", a 3-column template) and changed the templateDetails.xml file accordingly. Then I changed the template.css file from
Code:div#maincolumn_full { float: left; width: 720px; margin: 0 0px 6px 0; /*padding: 10px 0 0 10px;*/ }
to
Code:div#maincolumn_full { float: left; width: 100%; margin: 0 0px 6px 0; /*padding: 10px 0 0 10px;*/ }
Hi
That's my problem too. After a lots of tweaking, I found out that could not have the forum in full width, or else everything would act the same.
I'll try your solution or else I'll have to change the template.
Thanks for the reply!
I am also using Siteground templates but done changes there of font and Site background Page..
So I think may be my issue is not related to Siteground Templates but with any template and Kunena.
I have set body class in .css file as
body {
font-family:Arial, Helvetica, sans-serif;
line-height: 1.3em;
margin: 0px;
padding: 0;
font-size: 12px;
background: #D6CE8F url('images/Background.jpg') no-repeat;
background-size: 100%;
align:left;
overflow-x: hidden
If I assign this template with my site it is showing me Background image on all the Pages , when I click on menus, But not for Kunena forum. I have also linked Kunena forum with Menu as "index.php?option=com_kunena"
Can any body please throw lite on this..
Thanks a lot.
We have encountered many problems - dozens of problems - involving Siteground templates. It's difficult to classify one single issue but most of them have to do with Siteground's "collapsible module locations" (or lack of them) that restrict the allowable width for user's installations of Kunena. This is what was at the heart of Pescador's question (and what was at the centre of this discussion topic).
Your question is the first I've seen asking for help about some "background image". Perhaps your question deserves an entirely separate discussion topic? :S
While we look forward to your response, it might help you to read Before you ask for help with template issues ...
