- Thank you received: 1
Question migrating Joomla 1.x+Smf 1.x to Joomla 1.5+kunena Script
Make sure all the Dbase user password etc are allnindividually in quotes.
I will try to finish this code this week too
- brianfischer74
I no longer get the error message. I'm definitely not doing something right. Basically it flashes to my homepage right away. I go into Kunena component and do the recount category stats and nothing has changed.
I'm using the orignial converter and the updated sm2k.php and not the one you updated. Only because it sounds like the old one kept passwords. Maybe it's an issue of me needing to use your updated one.
My situation though is that I was running community builder and the joomlahacks bridge so basically they were entering through CB. I'm trying to avoid messing this up somehow so that when I'm in Kunena they still have access with their CB stuff.
You mention that you are working on finishing it. With my above situation Is it just best to wait until your done working on your updated script?
Thanks for the help already. I don't know much about this script stuff so everyone posts in here have been helpful.
You need to make sure the SMF and Joomla tables are in the same table
Also Kunena and CB integrate so no problems there
As for waiting, yeah unless you dont mind the formatting.
Basically it converts the <br/> but incorrectly, i am thinking of taking that out and then running an SQL script to fix that
- brianfischer74
"Smf and joomla tables are in the same table". Are you meaning they need to be in the same database. I have them together in that but don't know if I'm supposed to do something else as far as "tables".
Thanks.
As for users no you cant really jsut backup the user table as you also need the ACL tables filled inc correctly.
Backup allt eh ACL and user tables and you will be right though.
better however to do this in aother installation
- brianfischer74
What are the ACL tables?
What do you mean by on another installation? Do a fresh Kunena install?
I dont have a list at the moment, as am at work,
They are all the tables that either contain
"acl" or "aro"
Fresh istall = a new install of jooml and kunena for testing purposes so you dont need to alter your live environment
- brianfischer74
I am also using Tamir's original script with his updated smf2k.php file. I went that route because when I loaded up Kunena the users are appearing in there. So I thought I would give it a whirl to see if I didn't have to mess with users.
Thanks!
Done in 0
Creating Tables...
Truncating Tables...
Invalid query:
TRUNCATE TABLE jos_fb_announcement
Table 'inwardtr_sandpoint15.jos_fb_announcement' doesn't exist
- kraymitchell
- Junior Member
Any luck on tweaking that script some more?
- brianfischer74
One thing I would like to change though if possible is all the old posts show the "username" instead of the "real name". Danny if I use your script instead is it possible so that it would import this way so that the author is te real name? I also can't click on a poster and go to their profile. Guessing this is because I used the older script?
Danny if I use your script and it resets the password how does that work. if they login to community builder and then hit the forums does it give them a new password and they have to use this for all of joomla?
I did get the following below when running the script.
Invalid query:
update `sh3s_fb_users` set userid= ifnull((select max(t.id) from sh3s_users_old q,sh3s_users t where t.username=q.username and q.id=userid ),userid)
Duplicate entry '64' for key 'PRIMARY'
