Kunena 5.1.18 Released (30 Jun 2020)
The Kunena team has announce the arrival of Kunena 5.1.18 [K 5.1.18] which is now available for download as a native Joomla extension for J! 3.9.x. This version addresses most of the issues that were discovered in K 5.1 and issues discovered during the development stages of K 5.1.
Question migrating Joomla 1.x+Smf 1.x to Joomla 1.5+kunena Script
10 years 1 month ago #21 by Dannymh
Zend Optimizer is just a warning and wont have an impact on this at all.
Can you please let me know the results of the following queries?
SELECT count(*) as smf_messages FROM smf_messages
Select count(*) as kunena_messages from jos_fb_messages
That will tell us how many messages are in each of those tables and whether any have been imported.
Run both before and after the import script. If you trust me enough I will be happy to take a look if you want to give me "read" database access and php access
10 years 1 month ago #22 by kraymitchell
Hey Danny,
Here are the results:
PRE SCRIPT
smf_messages
21038
kunena_messages
1
POST SCRIPT
smf_messages
21038
kunena_messages
21038
It's strange though, because on the front end of the forum, I get:
Total Messages: 0 Total Subjects: 0 Total Sections: 6 Total Categories: 27
Let me know if you still want access to the phpMyAdmin.
10 years 1 month ago #23 by Dannymh
Ok this is all good, it tells us we have the posts, you need to now go into your Kunena backend and update the post totals etc.
Can I get front-end access to your site, or even admin access to kunena if you want. I dont mind jumping in for a quick look.
Dan
10 years 1 month ago #24 by kraymitchell
Danny, what about the users?
I have PMd you login information.
10 years 1 month ago #25 by Dannymh
Ok all sorted.
You just needed to go to
Admin >> Components >> Kunena >> Recount Category Stats
I ran this for you and you forum is all up and running now.
You can delete my account too.
Let me know if you have any issues. Also be aware that the conversion does not handle some characters perfectly so you will see their ASCII equiv, edit them where you see them. I will be changing this script soon to handle them though
Dan
10 years 1 month ago #26 by kraymitchell
Thanks for the help Dan,
Is there any way to get all the users over as well?
Also, I have noticed that there is no formatting attached to any of the posts, and everywhere there should be a paragraph break, there is 'rnrn' instead.
Any idea why it ran so fast instead of taking an hour+?
10 years 1 month ago #27 by Dannymh
Can you run the script again for me and then, create teh Danny user again and run the following query for me after you run the script
select count(*) from jos_users
I think this script is adding the users into Kunena but not into Joomla, lets do the above to confirm and if so i can write a quick dirty script to fix this
10 years 1 month ago #28 by kraymitchell
Should I run the script again as is, or should I start it all from scratch again? Your account is still active.
10 years 1 month ago #29 by Dannymh
run as is, the script will truncate all of the kunena tables anyway
10 years 1 month ago #30 by kraymitchell
count(*)
2
The users doesn't seem to be coming across at all it seems.
Running out to the gym, back in a bit.
  • Not Allowed: to reply.
Time to create page: 0.270 seconds
